Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles
Peters Pump Co.
I just acquired a pump with the name "Peters Pump Co. Kewanee Ill." cast into it -- assuming its a...
this thread has 1 replies and has been viewed 1339 times
Old 05-06-2006, 08:56 PM
Jonathan Shaw Jonathan Shaw is offline
Default Peters Pump Co.
I just acquired a pump with the name "Peters Pump Co. Kewanee Ill." cast into it -- assuming its a water pump of some sort--intended to be driven by a flat belt. Well actually there are 2 belt pulleys mounted side by side. This in turn drives a gear train and creates a reciprocating action at the pump cylinder. Anyone have any info on this brand ?? Thanks for any info you may have...
Old 05-09-2006, 07:55 PM
Mike S's Avatar
Mike S Mike S is offline
Default Re: Peters Pump Co.
Do you have any pictures of it? It probably works and looks about the same as most of the other piston pumps that are around. The most popular ones seem to be the Myers bulldozer pumps. I believe one pulley doesn't actually drive the pump and was used for starting and then the belt was pushed to the other pulley to run the pump. Someone correct me on this if I'm wrong.
Here is a picture of my Deming piston pump.
http://www.freewebs.com/mikesoldengi...e/deming_2.jpg
Breisch/Peters Old Engine Ken K Scale Model Engineering 6 02-29-2008 04:44 PM
Breisch / Peters Lil' Brother toesup Scale Model Engineering 9 01-19-2008 08:29 PM
Breisch & Peters John Davis Scale Model Engineering 1 04-25-2007 08:23 PM
Jay Peters Dennis Peters Antique Gas Engine Discussion 5 12-03-2006 04:21 PM
Peters Pump CO. Dan Burkart Antique Engine Archives 0 06-19-2000 04:36 PM
