Associated Low Tension Mag
I have a Associated four bolt low tension mag that I need to know the correct procedure to check...
this thread has 4 replies and has been viewed 687 times
Old 05-10-2006, 10:51 AM
Benny Mckheean's Avatar
Benny Mckheean Benny Mckheean is offline
Default Associated Low Tension Mag
I have a Associated four bolt low tension mag that I need to know the correct procedure to check it.It will not run the engine but when I put a volt meter on it while the engine is running off a battery and coil it reads about 1.5 volts DC the best I can tell. Thanks for any info Benny
Benny in NC
Old 05-10-2006, 07:45 PM
Shane Ball Shane Ball is offline
Default Re: Associated Low Tension Mag
Benny - 1st put your meter on A.C. and check it. With a flip of the gear by hand you need from 6 to 12 VAC. You can also hook up a 6 volt flash light bulb to it to test. With a flip of the gear you should get a bright flash from the bulb. If not take it apart and give it a good cleaning and check for lose connections. Ted Brookover shared this info with me long ago and I use it all the time. Good luck!! Shane
Old 05-10-2006, 07:52 PM
Procedure at the bottom of this page...
http://old-engine.com/maglma.htm
Harry's Old Engine Site My Videos
Old 05-10-2006, 09:04 PM
BobH BobH is offline
I have an Associated and it won't run when timed like it's supposed to with the buttons on the backof the mag. I had to try changing it one tooth at a time from the "correct" setting till it ran. I wound up off two teeth on the mag, your mileage may vary. Bob
Old 05-11-2006, 08:49 AM
Thanks all for the replies.I did a search and found where I had posted the same question 1 1/2 years ago when I first got the engine but being old and senile I forgot about it.I finally got around to getting the engine running and if I can get the mag working I will be done.Thanks all and this has to be the most knowlegable bunch of folks I have ever dealt with and thanks Harry for putting this site together and it is about time for my yearly dues. Benny
Benny in NC
Low tension mag Benny Mckheean Magnetos, Ignition Coils and Spark Plugs 7 03-26-2005 10:28 AM
Low Tension Mag ID Please Hank Czerwick Antique Engine Archives 2 10-25-2004 09:27 AM
Low Tension Mag Benny Mckheean Antique Engine Archives 7 10-15-2004 06:51 PM
Low Tension Mitch Basich Antique Engine Archives 2 09-06-2004 08:09 PM
low tension coils Ron McMorris Antique Engine Archives 4 12-09-2003 10:55 PM
