Lister magneto:shrug: Can anybody please tell me the correct magneto for a Lister J , planty of info out there...this thread has 4 replies and has been viewed 761 times
Can anybody please tell me the correct magneto for a Lister J , planty of info out there on A B D & L's but very little on the J, found three photos , but they don't match mine, it's got a M L in a oval then says type CK1, any help welcome, B K
I have an L Lister that uses an M-L CK-1 just like in the photos of your engine in your previous post. I guess early engines had a "flick" type M-L magneto from what I can tell, but mine is like yours, from what I can see.
Seems like a decent magneto, but there is no impulse or any means of retarding spark to start. I have not had a problem with kick-back, which is good because the engine needs to be cranked to start. I don't think I could start it flipping the flywheels. Your J looks more than a little bit like my L.... |
Well thanks for that at least I dont have to find the right magy , you haven't got any links to a manual by any chance?? I've seen photos of the L's and they are very similar, only bigger, mines heavy enough, progress photo.
I bought some reprint literature on eBay and the same stuff pops up over and over so don't try to outbid anyone for that. Same with decals.
Frankly, I haven't bothered reading the literature I bought because I got into running order thanks to help on this website. Search this site for Lister and/or look at my old postings and you should find most of the technical info or links to it that I utilized- thanks to Listerdiesel. One thing I never quite figured out was if I could remove the upper main bearing retainer casting with the flywheel still on the crankshaft. I needed to look in there to see the valve gear timing marks which can be seen if the upper retainer is removed but not only could I not get it off, a couple little pieces of the retainer flange were already broken off before I touched it. Removing the flywheel on that side of my "L" to gain enough space to pull the retainer out horizontally would be seriously problematic: There is a massive, two-step pulley in the way and it has a broken off set screw so that pulley isn't going anywhere soon. (Hmmm......seems like somebody else followed this same path a while ago but I don't much care for the results of their "work".) I was able to actually remove the idler gear, re-install it, and check the timing marks with the use of a mirror but I still wonder about that retainer. Does it have a nosing that prevents it from being lifted straight up and off? I need to build a trolley for mine. It can be shoved around on smooth concrete but that just ain't gonna get very far....... There used to be a link on here to a UK website that has a many of Lister enthusiasts postin and lot's of photos, too. See if you can find that, maybe ? |
Can tell you now Kid the flywheel has to come off, then the lower bearing cap , the the top cap, learnt that mineself, once you do it its easy, but beware the top cap has a location pin in it for the slipper, so dont force it, will cheack your old posts . thanks Kid,
BK |
| Need Lister ST Hat | glfarnes | Vintage Diesel Engines | 0 | 09-25-2007 05:53 AM |
| Lister age | George in Aus | Vintage Diesel Engines | 1 | 10-20-2004 05:04 AM |
| P.A. Lister | lonnie | Vintage Diesel Engines | 1 | 06-03-2004 06:23 PM |
| RA Lister | Jim G. | Vintage Diesel Engines | 1 | 01-15-2002 02:25 AM |
| lister | dave | Vintage Diesel Engines | 1 | 06-10-2001 02:06 PM |
