Need Shaft seal on RE-7 Champion Air compressor and some.
I have a 1949 Champion RE-7 air compressor with a bad shaft seal. The factory shows that its...
this thread has 5 replies and has been viewed 1057 times
Old 05-23-2006, 10:03 PM
Ram Ram is offline
Question Need Shaft seal on RE-7 Champion Air compressor and some.
I have a 1949 Champion RE-7 air compressor with a bad shaft seal. The factory shows that its obsolete and has "NO" informantion on this model pump except they made them between 1936 and 1956!
Does any one have a source for new old stock parts (seal and gasket set) for this unit. I think that it very closely resembles the R-10 and R-15 models, just don't know what all the differences are.
Hope to find someone who has worked on this model. I don't know PSI / CFM's or even have a manual.
Thanks for reading,
Gary
Virginia Beach
Old 05-27-2006, 09:00 AM
Default Re: Need Shaft seal on RE-7 Champion Air compressor and some.
If you have the old seal it helps, take it to a local parts store and match it up.Also measure the shaft and hole the seal goes into. They should be able to find a replacement.I've done this before and have had no problems....
Old 06-04-2006, 10:01 PM
Ram Ram is offline
Thanks will give it a try.
Old 06-17-2006, 11:34 PM
Ram Ram is offline
Well the good news is that I've actually found a shop that has the manual, gasket set, and a shaft seal, having all sent to me.
Thanks for the help all.
Gary
Old 06-22-2006, 05:12 PM
RAM...just a word of advice.....when you get it back together again do NOT use DETERGENT OIL!!!!!!!!
We sold a customer a new compressor and the instructions SAID to use detergent oil. I even CALLED and ASKED them and they said that was correct. Well...........that was news to ME................BUT our customer followed their directions.
Within a month it was JUNK.....ate itself to pieces.
I called the company AGAIN.....THIS time they told me the instructions were WRONG..........AND replaced the compressor.
Old 06-22-2006, 09:26 PM
Ram Ram is offline
Good point, Thanks. I was going to use Ingersol Rand synthetic air compressor oil vise dino oil any way.
Thanks again,
Gary
Converting A Vertical Shaft Lawnmower engine to a horizontal shaft Jordan Garden Tractors / Mowers / Scooters 18 06-16-2009 04:49 PM
Champion 400 forge blower brucegodlesky Blacksmithing and Metallurgy 6 06-29-2008 07:54 AM
Champion M-6 Mike Herbertson Small Air Cooled Gasoline Engines 5 09-28-2005 10:30 AM
Champion Compressor Randy Wells Antique Gas Engine Discussion 4 03-25-2005 10:24 AM
Champion #25 ihorse Antique Engine Archives 12 10-05-2004 11:06 PM
