Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Marine Engines
15 hp Sea King
I have a 1963 Gale (OMC) 15 hp Sea King,Mod.# GG18802A. Would appreciate any info particularly the...
this thread has 3 replies and has been viewed 1042 times
Old 05-27-2006, 03:07 PM
bronsonllh bronsonllh is offline
Default 15 hp Sea King
I have a 1963 Gale (OMC) 15 hp Sea King,Mod.# GG18802A. Would appreciate any info particularly the fuel mix ratio. thanks
Old 05-28-2006, 08:27 AM
Default Re: 15 hp Sea King
I've used 50-1 mix in all my 2 cycle motors for years, never had a problem.Even in an old scott atwater from the 50's. I have an 1965 evinrude 28hp that's been running fine since we got it 35 years ago with this mix.Of course I've had to redo the carb,point's condenser ect..but it should be fine at 50-1
Old 05-28-2006, 08:33 AM
Also make sure there is no water in the lower unit, fill it with 80-90 gear lube from the bottom plug till it comes out the top plug.Check it everytime you use it as it's old and may leak.Those gears are expensive and hard to get sometimes.If it's leaking you can get a seal kit from napa or a marine store by where you live.If there is no seal kit's avaiable anymore I've taken the seals out and went to the part's store with them and shaft sizes-hole dementions, and they match them up! Good luck! Tom
Old 05-28-2006, 11:22 AM
Thumbs up Re: 15 hp Sea King
Thanks, I'll check the seals first thing!
King pin help needed Will Antique Tractors - Old Iron Lugs, Cleats and Tracks 0 05-31-2006 07:17 PM
Farm king Sky Antique Gas Engine Discussion 4 01-20-2006 03:25 PM
Thermo King Richard Clarke Generators & Motors General Discussion 0 07-22-2001 10:33 PM
