Igniter question.How does one know that an igniter is firing? Other than that engine is running. A sparkplug...this thread has 2 replies and has been viewed 722 times
A sparkplug system can be tested by pulling the wire and close grounding. Turn the crank, get a spark, system good. But how can a simular test be preformed with an igniter with out removing it from the engine and running a ground wire for the test. I'm sure there is a simple answer, this is my first igniter engine. TIA |
A simple way to see if there is a circuit when the points are closed is to disconnect a battery lead and then hold the ignter points closed. Strike the battery terminal with the disconnected wire and see if it sparks.
Thanks. That makes timming a little more difficult but I think I can overcome if I at least know that there is a spark at some point.
| IHC igniter points question | Kevin Weis | Antique Gas Engine Discussion | 7 | 02-19-2007 10:45 PM |
| Webster igniter question | Kevin Weis | Magnetos, Ignition Coils and Spark Plugs | 3 | 07-08-2006 11:30 PM |
| Question about a F&M igniter | Randy Stafford | Antique Engine Archives | 1 | 08-08-2004 02:51 PM |
| igniter question | Alan Ruschman | Antique Engine Archives | 3 | 09-05-2003 07:43 AM |
| Associated Igniter Question | Alan R | Antique Engine Archives | 7 | 10-25-2002 10:52 PM |
