| Small Air Cooled Gasoline Engines Briggs & Stratton, Clinton, Lauson, Maytag, Nelson, Wisconsin and other small air cooled engines. |
Briggs & Stratton Model 6 (model N)Hi, Here In holland I have an old Army power unit. This is powered by an B&S Type 6 (this is the...this thread has 5 replies and has been viewed 4705 times
Hi,
Here In holland I have an old Army power unit. This is powered by an B&S Type 6 (this is the old N model). I'm looking for a technical manual (internet??) so I can adjust the valves. Does anybody now where I can find it? Gr Gertjan |
B&S models 5,6, and 8 all have the same specs for valve clearance.
Intake -- .007 inch minimum .009 inch maximum Exhaust -- .014 inch minimum .016 inch maximum The valve are adjusted when the engine is COLD. Kent |
Kent's info. is right on. I'll just mention that the valve clearances should be stamped on the lower part the aluminum ID plate riveted to the cylinder air shield. The left no. will be for intake, right for exhaust. Since you mentioned the model no., I'm assuming the data plate is still on the engine. You might try hunting eBay for the tech. manual. It may be a long hunt, but these things usually surface there.
The info I posted is from the B&S Service Manuel for out of Production Engines 1919-1981. B&S P/N CE8069-5/00.
Kent |
Here is the main Briggs site where the manuals are listed:
http://www.briggsandstratton.com/eng...20Manuals.aspx Good luck with your engine! --Jack https://sites.google.com/site/antiquebriggsandstratton/ |
Here is another site as well http://www.oldengine.org/members/mur...nformation.htm
| Briggs and Stratton Model NR6 | Chuck S | Small Air Cooled Gasoline Engines | 28 | 05-10-2013 06:57 PM |
| Briggs and Stratton model AP | jakewells | Small Air Cooled Gasoline Engines | 7 | 10-18-2007 12:37 PM |
| Briggs & Stratton Model 6B-S | Bill Sherlock | Small Air Cooled Gasoline Engines | 6 | 06-28-2007 11:16 PM |
| Briggs & Stratton model ZZ | jerryows | Small Air Cooled Gasoline Engines | 2 | 02-07-2006 10:43 PM |
| Briggs and Stratton Model A | Pollack Pete | Antique Engine Archives | 4 | 09-14-2003 11:32 PM |
