Was the B&S kickstart Y only on washing machines?
this thread has 6 replies and has been viewed 2115 times
Old 06-05-2006, 06:54:43 PM
Mike S's Avatar
Mike S Mike S is offline
Default Was the B&S kickstart Y only on washing machines?
Was the Kickstart Briggs model Y only used on washing machines or on other equipment as well? I want to hook one up to a pump and was wondering what the most authentic starter would be for this application ( kick, handle, or rope). Which starter was standard to the engine if you bought it new from Briggs?
Old 06-08-2006, 04:45:03 PM
Sean B. Sean B. is offline
Default Re: Was the B&S kickstart Y only on washing machines?
Mike, I think MOST of them were used on washing machines, but not all of them. In the book "the legand of Briggs and Stratton" on page 73 there is a picture of one mounted on a model 100 powercharger unit. It mentions there use on PC100 and PC200 units as well. These units were before the ones built with the WM series engines. I dont know about the starter, I have only seen the foot start type, but you could probally use the rope start cup if the foot pedal wouldnt work. Good luck with your engine!
Old 06-08-2006, 07:09:56 PM
The parts list that I have for the Y only shows the kick start. I've never seen one with a rope start.
Old 06-08-2006, 10:19:17 PM
Mike in NC's Avatar
Images: 64
Our parts list shows a rope start pulley Part Number 61415. They also came with a Lever start. The kick pedal is the most common.
Old 06-08-2006, 11:41:19 PM
Kelly Barnett's Avatar
Kelly Barnett Kelly Barnett is offline
Images: 15
It should also be added that the rope starter was a cast iron cup. The hand starter was also made of cast iron. The kick starter has many variations. I'm not sure of how many different types there are. I think I have five different styles of the kick starter pedal. There might be more. I'm not sure. I agree that the rope cup and the hand starting style are the more difficult models to find. Have fun collecting and displaying.
Old 06-09-2006, 02:08:19 AM
John Newman, Jr.'s Avatar
Below is a picture showing a straight and a curved Model Y starter pedal. I may be dreaming, but I think I have seen a curved pedal that goes the other way - curving out away from the flywheel. Then there is the small tooth gear (earlier) Vs. the big tooth gear (later).
I think I have a blower housing from one that had a lever starter. It has a bracket with a rubber bumper attached that would be at the right position for the lever to rest against.
I have one with a rope start. Don't recall the Type # off hand, but it is noticably different than a kick start Type # (If I'm thinking of the right tags, I believe it has a 3 instead of a 6 in the third digit.....)
I feel the Type with no PTO crankshaft extension can definately be tied to washing machine application. Ones with a 'standard' crankshaft could have been used on anything.
One part that seems to turn up missing quite frequently is the tin cover for the starter clutch gear. However, on Types with no PTO crank extension. they never had one since the drive pulley was on this end of the crankshaft.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 06-09-2006, 10:45:25 AM
Mike S's Avatar
Thanks for the replies.
John- I think I've seen them with the pedal curving away from the flywheel, too.
Briggs Kickstart pedal in reverse. James Wallace Small Air Cooled Gasoline Engines 3 02-06-2008 11:57:58 AM
Ironhorse kickstart engine Alex F Small Air Cooled Gasoline Engines 5 03-14-2007 10:29:23 AM
What washing machines were WM's used on? Mike S Antique Washing Machines 5 04-18-2006 06:12:42 AM
Threshing Machines Old Iron Mike Antique Engine Archives 1 11-03-2003 11:58:59 AM
Hay Baling Machines Mark Bastable Antique Engine Archives 9 01-31-2002 11:14:28 AM
