Have patience (Generac)
A friend asked me to see if I could get a generator running for him,so I said I'd see what it would...
this thread has 10 replies and has been viewed 3929 times
Old 06-16-2006, 02:44 PM
realkeifer
Default Have patience (Generac)
A friend asked me to see if I could get a generator running for him,so I said I'd see what it would take. Turns out finding any information on this this is turning out to be more work than I thought.Here's what information I could find on this thing.
Sears 1000 alternator (yes thats right) alternator
Model #580.3149
serial number 84755
Talking to sears was like pulling teeth, they have no records of this model.
On the side of the engine crank cover it says CLINTON ENGINE CORP. MAQUOKETA,IOWA. The only numbers that I found that i thought might be usefull were on a plate located on the cooling fins and they read as follows.
MOD 500-0300-047 SER 60502596.
The engine feels like it has compression, but needs a new float bowl and carb rebuild kit just to get it started. I'm not sure if this is worth even fooling around with, but I hate just giving up. Not even sure that if I get it started that the alternator even works, but like I said,I hate to just give up. If anyone could direct me on where to get parts in michigan for this thing,it would be muchly appreciated.
Old 06-16-2006, 08:23 PM
Default Re: Have patience
Try searching for the model number (580.3149) at www3.sears.com, you might find a parts list.
A couple of Harry's advertisers sell Clinton parts. Look on the carb to see if it says "Carter N" on it anywhere. If it does then you're in luck, kits are still available for that carb. Kits for other carbs are available but the Carter N kits are the easiest to find.
Along with anything else you do, you'll want to file and reset the points and maybe replace the condenser.
Old 06-16-2006, 08:26 PM
Check your model number, you may have missed a couple of numbers at the end.
Old 06-16-2006, 09:39 PM
John Newman, Jr.'s Avatar
According to the Sears Supplier list, a 580.XXXX is from Generac Corp. This probably won't help much since if you take a look at the Generator board on this site, this company has been discussed at length about their lack of customer service and information.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 06-21-2006, 11:35 AM
Retiree Retiree is offline
Question Re: Have patience (Generac)
i have the original wiring diagram in my sears alternator books.on the model number it lists as 580.31490 -31494.is that a 2 cycle motor.it lists a clinton 2 and three quarter hp clinton.but all i have is the wiring schematic .it dates back to 1976 in my wiring book.is that anything like what u have or is it a 4 cycle motor.don
Old 06-21-2006, 03:38 PM
Default Re: Have patience (Generac)
Clinton model 500 is a 4 cycle engine according to my parts book.
Bill
Old 07-11-2006, 05:21 PM
vic b vic b is offline
Unhappy Re: Have patience (Generac)
I also am having problems finding information on a Generac portable generator s4002.Mod#8973 0 ser#854334.If I can find the right voltage regulator board I will buy it,but I would be more interested in a schematic of this board so I can build my own HEAVY DUTY version of it.The board is shown on some schematics but there is no parts breakdown of the board itself.The board in my unit is filled with some kind of epoxy to prevent one from repairing it themselves.Any help or info would be appreciated.TNX ALL,Vic
Old 11-28-2006, 05:52 PM
roeb
Realkeifer: The Clinton engine model and type 500 0300-047 is a 2 cycle, 5/8" Dia. keyway 2 3/4 HP. 2 Cycle , full float carburator. Horizontal shaft Engine.
The 500 (even Number) indicates Horizontal shaft, the 0 indicates Recoil Starter, the 3 indicates Flange Mounting Ball or Roller Brg., The next 0 indicates Without PTO, the next 0 indicates 1962 First year of Release and Production, The 47 indicates model variation. Your Engine must have been made after 1962 as my parts book only goes to variation 18 and is of May 1962 origin. The carb. PN is 39-783-5, Bowl 25-41-5, Carb. repair kit 149-595. Hope this helps....roeb
Old 11-28-2006, 06:05 PM
roeb
RealKeifer: Checked my supply of Clinton parts and could not find any you needed. You can try the following Jim Freshman jpfreshman@net.zero.net Barry Peterson peterson@tbhnet.net, or maybe your best bet Fill Mayberry 563-652-2411 who bought out what was left of the Clinton Stock. You can also try Clinton Engine products, P. O. Box 860, Maquoketa, IA Hope this helps: roeb
Old 11-17-2007, 07:54 PM
tasturbo86 tasturbo86 is offline
Did you ever get this going?
I have a Clinton engine from a 580.3199 generator.
Let me know what happened.
Thanks, terry
terryas@mindspring.com
678.617.-730
Old 04-30-2008, 12:45 PM
realkeifer,
Did you ever get any parts for the generator? I have two of these motors now and some spares if you need them.
Terry 678.617.0730
Old RV Generac Arthur Generac Generators (SEARS, etc.) 9 09-11-2009 09:37 PM
Generac ChrisMar Generac Generators (SEARS, etc.) 1 02-10-2008 05:49 PM
Patience pays when buying old iron. Keith Johnson Antique Gas Engine Discussion 9 11-18-2007 01:23 AM
generac pwest Generac Generators (SEARS, etc.) 1 09-14-2004 11:51 AM
patience is a virtue... so is impatience Marty Antique Engine Archives 11 12-15-2002 07:40 PM
