| Antique Engine Archives All archived posts from 1999 to 2004 when SmokStak was on EnginAds. This is a read-only board. |
John Deere 1 1/2 Type E main shems/torqueHello, I'm about to put a new crank and flywheels on a JD 1 1/2 H.P. stationary engine. Is there a...this thread has 3 replies and has been viewed 814 times
Hello, I'm about to put a new crank and flywheels on a JD 1 1/2 H.P. stationary engine. Is there a torque setting on the main bearing bolts? and How do you know how many (if any) shems to use?
Thank you all, Tim |
When replacing main bearing shims always place the shims snugly against the crankshaft. Put plenty of shims in (equal amount on each side), tighten the bolts reasonably tight (I don't know what torque). Then lift up on each flywheel to check for play in the bearings. If any play is felt, remove cap and take out one thin shim and reassemble. If necessary remove additional shims from alternate sides. The bearings should be snug, but not tight enough to bind. Same with the rod bearing and shims. It has to be done by trial and error.
Thanks Stanley....just what I needed.
Hi Tim! When I disassembled my 1 1/2 E I used a torque wrench. The main bearings broke loose between 65-70 ft. lbs &the rod bolt between 35 & 40 ft. lbs. A collector at the Sandwich Show (he had restored an 1 1/2 E)told me the flywheels should stop (when spun by hand) in 4 or 5 revs when the bearings are tight enough. Same for the rod bearings. Larry I hope to have mine back from machine shop soon so I can start getting it back together
| John Deere 1 1\2 hp Type E 315458 | Jerry B | Antique Gas Engine Discussion | 2 | 08-31-2007 01:14 PM |
| John Deere Type E | dhatfiel | Antique Gas Engine Discussion | 4 | 07-21-2007 11:43 AM |
| John Deere Type E Manual | JohninMi | Antique Gas Engine Discussion | 2 | 07-10-2006 02:14 PM |
| John Deere Model E Head Torque | Dave U | Antique Engine Archives | 4 | 03-26-2003 10:53 PM |
| john deere type E | bob adams | Antique Engine Archives | 1 | 10-21-1999 07:42 PM |
