Go Back   SmokStak > SmokStak® Antique Engine Community > Vintage Diesel Engines
Whitte 5 X 8 hp?
Hello all, I'm yet another newb, having lurked for months and being new to old engines, I, of...
this thread has 3 replies and has been viewed 743 times
Old 06-22-2006, 04:43 PM
Paul P Paul P is offline
Default Whitte 5 X 8 hp?
Hello all, I'm yet another newb, having lurked for months and being new to old engines, I, of course have many questions. I'm thinking of buying a Witte diesel generator, the owner knows less about it then I do, its a horizontal 5" bore with an 8" stroke, rated at 720 rpm. Any idea what hp this unit may be, and what its kw output may be. Its got the Witte cast gen base, but I have no info re the gen output. Please help. In the meantime I'll press on with getting my 9hp Z up to snuff. Thank you all in advance.
I've cross posted to the Generator section as well.
Paul P
Old 06-23-2006, 02:04 AM
D. Johnson D. Johnson is offline
Default Re: Whitte 5 X 8 hp?
You have one of two Witte Dieselectric units.
Model MD: On this engine the valve springs are not covered.
Model CD: This engine has a valve cover.
The Witte MD is the earlier version of the CD engine.
David Johnson
djoh175046@ cox.net
djohnson@arrowengine.com
Old 06-23-2006, 03:12 AM
ListerDiesel's Avatar
ListerDiesel ListerDiesel is online now
There is a Witte Horizontal CDRC model listed with 5" bore and 8" stroke, weight of the engine alone is 1615 lbs, hp is 12 @ 720rpm.
That would run to 7.5kVA or maybe 8kVA.
They list a 10kVA electric plant, using that engine but that would need to run at a higher speed to develop the extra power required.
Information from the 14th Ed Diesel Engine Catalog.
Peter
Old 06-23-2006, 09:16 AM
Thank you David and Peter, can you suggest a book that has the specs as well as pictures to help identify engines in the future. Thanks again for your expert help.
Paul
Whitte 6hp headless hhound Antique Gas Engine Discussion 1 07-16-2006 02:56 PM
Whitte engine fix up Jack Antique Engine Archives 0 01-02-2004 10:37 AM
Need a connecting rod bolt for my Whitte Chris Kirk Antique Engine Archives 0 08-26-2003 09:32 PM
Whitte timming randy Antique Engine Archives 5 03-02-2001 03:56 PM
Whitte engine David L. Showerman Antique Engine Archives 1 09-08-2000 10:33 PM
