timing John Deere Mag
I am working on a 1 1/2 hp John Deere and I would like to check the timing of the mag . I can see a...
this thread has 1 replies and has been viewed 993 times
Old 06-25-2006, 10:45 PM
Dale White Dale White is offline
Default timing John Deere Mag
I am working on a 1 1/2 hp John Deere and I would like to check the timing of the mag . I can see a mark on the mag gear , but no other marks . What do I line this up with .
Old 06-26-2006, 08:40 AM
Warren Pennington Warren Pennington is offline
Default Re: timing John Deere Mag
Dale....the timing mark is there but they can be a real "booger" to see. If I recall right they are located just under the gear face on the radius of the gear. But you can time it using the push pins located on the mag. Roll the engine over in the correct direction just till the ignitor snaps. (note which way the mag gear rotates while doing this....I believe its to the left or CCW) The front of the mag has 2 push pins....a L for Left or CCW and a R for Right or CW. Push in on the pin that corresponds to your gear movement and rotate the mag gear untill you feel the pin drop in its detent. Holding this pin in assemble the mag......warren
Timing the John Deere Model E 3 1/2hp Leed3 Antique Gas Engine Discussion 2 04-15-2013 04:40 PM
John Deere BO Timing?? RIRR Antique Tractor Talk 2 05-20-2007 10:34 AM
john deere mag timing John Hopkins Magnetos, Ignition Coils and Spark Plugs 8 03-23-2006 08:39 AM
John Deere E 1 1/2 HP Roger Thornton Antique Engine Archives 1 02-15-2004 09:38 AM
John Deere 3HP Mag. Timing Bob Kelly Antique Engine Archives 3 07-11-2002 12:10 AM
