Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Marine Engines
Info wanted on older Johnson engine
Hi . I am looking for information on a motor i just aquired. Johnson name on a the black handle....
this thread has 2 replies and has been viewed 723 times
Old 06-28-2006, 03:19 PM
David Heggie David Heggie is offline
Default Info wanted on older Johnson engine
Hi . I am looking for information on a motor i just aquired. Johnson name on a the black handle. serial 44799. Mod HA 10. has 2 spark plugs champion J8 other markings on castings 43D178 and 43E200 alcoat. underwater exhaust.rope start from the top and plugs at the back enclosed in case, oval gas tank on front with red and white lable partially make out Johnson's and A-HO. Thanks david
Old 06-28-2006, 11:50 PM
Default Re: Info wanted on older Johnson engine
Sounds like a 10 horse but i'll check at work tomorrow,We should have the serial numbers in the books there.Tom.
Old 06-30-2006, 08:46 AM
Oop's was I off! It's a 2.5 hp from 1940.Nice little motor, have fun with it!
johnson Iron Horse Engine info ? cerwin Small Air Cooled Gasoline Engines 1 09-01-2006 08:54 AM
Older Kohler Help Wanted Steve A Kohler Generators 0 06-12-2005 09:32 PM
Fuller Johnson Info Wanted Andrew Albrecht Antique Gas Engine Discussion 7 05-17-2005 10:14 AM
Info for an older Onan single? Dusty R Onan Generators 8 03-11-2005 02:11 PM
Info wanted Johnson Utilimotor E.C. Mims Antique Engine Archives 4 07-27-2002 01:40 AM
