Go Back   SmokStak > SmokStak® Antique Engine Community > Vintage Diesel Engines
Gov Liquidation - Lister Petter / Stamford
STAMFORD AC GENERATOR, TYPE BCA-162-F16, 15KW/ 18PF/ 20V/ 27EXVOLTS/ 15A/ 18. 75KVA / 3600RPM/ 52A,...
this thread has 3 replies and has been viewed 1106 times
Old 07-02-2006, 07:57 PM
Jim Davis Jim Davis is offline
Default Gov Liquidation - Lister Petter / Stamford
STAMFORD AC GENERATOR, TYPE BCA-162-F16, 15KW/ 18PF/ 20V/ 27EXVOLTS/ 15A/ 18. 75KVA / 3600RPM/ 52A, W/ 4 CYL LISTER PETER DIESEL WATER COOLED ENGINE
I was surprised by the 3600 RPM. There are a lot of mistakes in that description and maybe the rpm is also a mistake. Anybody know of a 3600 RPM genset powered by a Lister Petter? There are three of them starting tomorrow by sealed bid at:
http://cgi.govliquidation.com/auction/view?id=897746
Jim Davis
Onan 45.0EM-15R-Spec.J
Onan 30.0DDA-3R-Spec.D
Old 07-02-2006, 11:50 PM
B.Sparks B.Sparks is offline
Default Re: Gov Liquidation - Lister Petter / Stamford
That's a Lister-Petter LPW3 engine. Unlike the older Lister engines, this one is rated to run at 3600 rpm. At that speed it produces 29.6 hp, just about right for a 15 kVA genset.
Old 07-02-2006, 11:53 PM
OOPS! I meant 15 kW, not 15 kVA... Also, despite being described as a "4 cylinder" it is indeed a 3-lunger.
Old 07-03-2006, 01:21 AM
Franzİ Franzİ is offline
Registered 0
When it comes to dealing with Government Liquidation, take a whip and a chair with you when you go to look at the machine, and photograph it from all angles. If you're the successful bidder, you have a 1 in 10 chance of getting what you bought and paid for, unless you are a regualr volume buyer.
Lister and Petter Engines quickies Vintage Diesel Engines 0 08-16-2007 11:39 AM
Lister Petter - it runs! Mudcat Vintage Diesel Engines 6 04-21-2007 04:51 AM
Lister Petter TR2 with 10 KW generator Larry Harter Vintage Diesel Engines 3 02-17-2007 10:23 AM
Lister Petter BA1 Shadow B Vintage Diesel Engines 1 12-22-2005 02:45 AM
Lister Petter 25&30 Kw gen set Andy H Vintage Diesel Engines 0 11-12-2005 06:06 PM
