Webster mag poits opening
Can anyone advise as to how far the points should open on a igniter outfitted with a AMM Webster...
this thread has 2 replies and has been viewed 577 times
Old 07-03-2006, 10:53 PM
Kevin Weis Kevin Weis is offline
Default Webster mag poits opening
Can anyone advise as to how far the points should open on a igniter outfitted with a AMM Webster magneto. This goes on a 1 1/2 hp Rock Island. Problem I'm having apears that there is insufficient spark to fire the gas mixture. It appears that with the head off and triping the magneto it was getting a spark but not very big and that the points were opening less than a 1/16 inch. However when tripped manualy it puts the mag springs in more tension and forces the points to open more and creates a bigger spark. Also the movable igniter point spring that holds the points closed is quite stiff. Could this be the problem with the return of the armature not able to move the points apart far enough to creat a sufficient spark? Any thoughts appreciated. Thanks - Kevin
Old 07-04-2006, 01:28 AM
Dan Baalman Dan Baalman is offline
Default Re: Webster mag poits opening
I am no expert on the Webster but I recently had a problem starting one of my Webster equiped engines so I took it to the farm and recharged the mag, and wow what a difference. It had always ran well but it has a really hot spark now. I recharged three extra mags the same time and tried them on different brackets. It didn't seem to matter much how far the points opened, they all had a hot spark. I usually set the set screw on the points to have the points open at rest. They close when tripped. That works best for me. I know there is a difference of oppinion. I would pursue the mag recharge if at all possible.
Old 07-04-2006, 02:16 PM
Thanks Dan, That makes sense to me to have the points slightly open at rest as otherwise it seems the current wouldn't be as strong once the armature reaches the stopped position. Think also I'll take you up on the suggestion to get the mag charged. - Kevin
Cat-426 hood opening Backfire Antique Tractor Talk 0 03-16-2008 12:18 AM
C.I.A. Job opening (joke) "TheToolman" Smoke, Flames & Gas (Off Topic) 0 03-28-2007 11:36 AM
High Opening Bid Mike Smith Antique Engine Archives 22 02-12-2004 01:29 PM
Sparkplug opening in Jaeger Kenny Towne Antique Engine Archives 4 09-15-2003 11:56 AM
off subject: opening packages suggestion Laura and Brady Antique Engine Archives 9 02-09-2003 09:26 PM
