2 HP Clinton needs help
49 Clinton on Choremaster runs well when it starts . Pops crackles spits sputters cold or hot when...
this thread has 4 replies and has been viewed 1732 times
Old 07-05-2006, 06:31 PM
BillyBob BillyBob is offline
Default Clinton 2 Hp needs help
49 Clinton on Choremaster runs well when it starts . Pops crackles spits sputters cold or hot when trying to start . plug fires blue . good compresion clean carb .(would like to know proper float level) i am not a stranger to old engines . would hate to trade it in for a Honda Bill KY
Old 07-05-2006, 08:27 PM
skartguy skartguy is offline
Default Re: Clinton 2 Hp needs help
Check the plug first make sure its not a resistor type i have also had new plugs do the same thing fire good outside but under pressure no go .. also check the valve timming and clearence good luck..steve
Old 07-06-2006, 12:04 AM
Sky
float level should be parelel with the body of the carb, if it isn't setting straight across, but a little too much down or up, that could cause running problems, also might be in the carb adjustments aswell. and just like skartguy said, could be a plug too, plugs fool alot of people thinking there good but there not, a plug though is just a possible problem. also might check to see if your points are clean and set properly. and the other half is what i would recomend to, what skartguy said.
Old 07-06-2006, 02:36 AM
Exclamation Re: Clinton 2 Hp needs help
Some Clinton engines were like the License built techempseh engines that REO built. They were cold blooded engines, and had to be warmed up, before a load was applied. Idle mixture was usually set a tad rich, to allow the engine to idle for a minute or 2, before opening the throttle. I had a 1962 REO snow blower, with the license built techempseh. I used to have to heat the head of the engine with a propane torch, in order to start this engine, if the outside temp fell below 15 degrees F
Old 07-06-2006, 03:53 PM
Default Re: 2 HP Clinton needs help
Thanks for the suggestions . A new plug and carb ajustments and the Choremaster runs again ! not much room for carb adjustment 1/4 turn either way will barley run. Bill KY
Clinton enigne TheEngineGal Small Air Cooled Gasoline Engines 17 02-08-2007 08:26 AM
clinton mystery realkeifer Small Air Cooled Gasoline Engines 6 06-20-2006 01:16 PM
clinton Kyle McGee Small Air Cooled Gasoline Engines 2 08-09-2005 11:59 AM
How many HP? (Clinton) Marlin K Small Air Cooled Gasoline Engines 1 04-11-2005 09:35 PM
Clinton ID Robbie Ramey Antique Engine Archives 1 01-10-2002 06:47 AM
