Dating a Licwelder DC225/3ASI inherited a Lincwelder DC225/3AS that the Onan engines needs some major work on. The plate on the...this thread has 3 replies and has been viewed 1235 times
I inherited a Lincwelder DC225/3AS that the Onan engines needs some major work on. The plate on the welder says Type:K1192SM1 & Serial #1730. The tag on the engine is gone. I've looked at Lincolns web site, but these numbers don't match anything there. Can anyone date this machine from these numbers?.
Also I've been told that Onan is no longer being manufactured & parts availability is becoming scarce & $$$$. Has anyone found a direct replacement for the Onan on this particular welder. One last Question, the 3KW of auxilary AC power says its @ 50Hz. Where these models built for the European market?, As Ac power in North America is 60Hz. http://www.smokstak.com/forum/attach...1&d=1152899410 Thanks Doug |
I don't know what year it is but I had a twin to it. 24 volt starting system thru the generator / welder. Mine was 60cycle. Sold it running for $250 about 3 years ago.
"When guns are outlawed, only outlaws will have guns" Jim Sherman
I rechecked the data on the front of the machine & the 50hz rating for the AC is at 3000 rpm, so 3600 rpm would make it 60hz. If my memory is working I think the rated rpm of the Onan is 3600.
From what I've been able to find the engine is a CCK model?, is this correct. Can anyone tell me what the difference is between the CCK A & CCK B models?? Thanks for your help Doug |
CCK 16 hp
CCKA 18 hp CCKB 20 hp |
| Help Dating OLDS 5A | Oldsiron | Antique Gas Engine Discussion | 18 | 09-17-2008 05:39 PM |
| Dating: IHC Mogul ? | Dusty | Antique Gas Engine Discussion | 1 | 10-01-2007 12:19 PM |
| Dating an AKN | bbunn1 | Small Air Cooled Gasoline Engines | 2 | 10-09-2006 07:51 PM |
| Stewart Little Wonder dating | Dan Wiese | Antique Gas Engine Discussion | 19 | 07-14-2006 05:42 AM |
| dating mccormick 10-20 | Mtype | Antique Tractors - Old Iron Lugs, Cleats and Tracks | 6 | 12-17-2005 07:53 AM |
