Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engine Collectibles
Maytag 72-D Eiseman magneto coil
Hello all, I'm currently running my 72-D with a battery and motorcycle coil. I'd like to...
this thread has 4 replies and has been viewed 991 times
Old 07-24-2006, 11:15 PM
KeithW's Avatar
KeithW KeithW is offline
Question Maytag 72-D Eiseman magneto coil
Hello all,
I'm currently running my 72-D with a battery and motorcycle coil. I'd like to get the original magneto setup back together. The coil that came with the engine was an incorrect single plug coil. I am looking for either a good used two plug coil or a dead one I can take apart and see about rewinding.
thanks,
keithw
Old 07-25-2006, 11:31 AM
K D Redd K D Redd is offline
Default Re: Maytag 72-D Eiseman magneto coil
Go to www.magnetoparts.com He is having new coils wound for the twin Maytags.
Kent
Old 07-25-2006, 11:52 AM
KeithW's Avatar
Correction, he was. I was on the waiting list for over a year then was told he was no longer doing them. A little frustrating since he still has his ad in GEM advertising them. Enough of that silliness, our venders are wonderfull, but like all of us things happen that are beyond our control.
I'm in the process of taking apart the incorrect dead mag coil apart. Looks to be pretty straight forward coil winding job. Working with 40 Ga wire is always a challenge but not undoable. The high tension lead outs on a two plug coil present some problems. I think the approach I would take is to make the secondary two seperate windings in series. That way the two output leads can be kept far apart and the chances of internal arcing would be reduced. Seems like a fiberglass spool would be a good start. Good high voltage properties and will make rewinding easier. I don't expect to get it right the first time.
keith
Old 08-27-2006, 02:22 PM
Red face Re: Maytag 72-D Eiseman magneto coil
The secondary on the 72 D and DA is a pass thru coil, it does not ground to the block. Hi tension goes thru 1 plug, the block, the other plug, and back to the coil. It has to jump 2 gaps. You probably will not have enough room for 2 independant secondaries will you? Space is at a premium on the twin coils. As for the other guy making coils, I bought one, and it would not fit behind the fly wheel. I contacted him to see if he shipped me the right one, and he told me he did. I tried to alter the outer shell to fit, but the secondary leadouts arced to the flywheel instead of the plugs. I too am looking for coils - for both the D and DAs
Old 08-27-2006, 09:05 PM
KeithW's Avatar
My thought was to wind two halves on the secondary. Keeping the two high tension leads away from each other and away from the ground takes a bit of work. I can see why they had such a problem with them.
keithw
Maytag 72 coil Frank Timmermeier Maytag Engine Collectibles 2 03-10-2008 10:47 AM
Maytag 72 coil Frank Timmermeier Maytag Engine Collectibles 4 02-17-2008 04:19 PM
Maytag coil voltage Frank Timmermeier Maytag Engine Collectibles 2 11-24-2007 10:32 PM
maytag coil BobRR Antique Engine Archives 10 10-18-2001 07:22 PM
maytag coil larry harding Antique Engine Archives 6 05-20-2001 10:13 PM
