webster testing
What is the best or correct way to test a Webster mag with a volt meter? Do you just spin the...
this thread has 5 replies and has been viewed 818 times
Old 07-26-2006, 09:20 AM
Kevin Weis Kevin Weis is offline
Default webster testing
What is the best or correct way to test a Webster mag with a volt meter? Do you just spin the shaft for a direct reading and how fast would it have to rotate for an accurate reading? What should the reading be? The Webster I got is a model AMM that was on a Rock Island/Alamo 1 1/2 hp. Any thoughts appreciated. Thanks - Kevin
Old 07-26-2006, 11:23 AM
Ken Majeski's Avatar
Images: 34
Default Re: webster testing
Acording to what I have here the Webster MM should put out a minimum of 13 volts and 60 Cycles AC at 599 RPM... You can spin it with a variable speed electric drill after you remove the springs.....
Old 07-26-2006, 10:45 PM
Thanks Ken, I'll get a volt meter shortly and see what I come up with. Thanks again - Kevin
Old 08-01-2006, 10:12 PM
Ken, at approximately 600 rpm I'm getting about 6 volts more or less. I take it this is not good as you say it should be around 13 volts. Is this indicative of the magnet needing recharging? When I first got it the armature was rubbing the poles due to worn plate bearings. Put new plate bearings on dosen't rub anymore but could now the gap between the armature and poles be too great and hence the voltage drop?. Thanks for any responses - Kevin
Old 08-02-2006, 04:17 PM
Images: 34
Yes, Magnets could be weak, There could be a buildup of Rust, Dirt, ect where the magnets contact the pole pieces.... There could be a shorted turn or two in the coils.... Or like you say the armature is worn causing too much clearance.
Also if the magnets have been charged Backwards they never seem to be quite the same....
Some say Never to remove the magnets... BUT... I have always removed them to clean and Charge... Then put a keeper on them before you remove them from the charger and when you slide them on the mag just push them down and push the keeper off the rounded end.
If someone has replaced the coils with the wrong ones they could have less turn turns which could cause low voltage.
I remember we had a 1 HP Ingeco once.... Had a Small Webster with only one Little magnet.... Never did get the Dam Thing to work... Does your Mag have one magnet or two...????
Old 08-02-2006, 10:05 PM
Ken, It has two magnets being an 'MM'. I saw from similar threads to check the ohm between the ground and primary wire and that it should read between 8 and 12 ohms. Mine read a little over 9 which I take is acceptable. With the points closed on the igniter it read 0 which I take is good. I should say before I go too much further that I sent the whole thing off to Mark's Magneto for the once over today for proper testing and recharging of magnets or whatever it needs. The consensus from the other threads was to leave re-charging of magnets to a professional which I have done. Appreciate all the advise and information as I'm now fairly confident on what repairs are likely needed. Thanks, Kevin
Webster Inverted Gas Engine - Webster Mfg Co David Sundry Antique Gas Engine Discussion 3 01-15-2007 02:30 PM
Testing a 15 KW JC Luker Onan Generators 7 10-31-2006 02:04 PM
Testing a Webster magneto JBailey Antique Gas Engine Discussion 2 05-11-2006 11:33 AM
testing Steve Kreiner Antique Engine Archives 6 06-27-2004 08:32 PM
testing Rich Martz Antique Engine Archives 2 05-22-2004 02:30 PM
