Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engine Collectibles
Maytag 92 Fuel Problem
Picked up a model 92 Maytag at the Adams TN show a couple of weeks ago. Will only run if I keep...
this thread has 6 replies and has been viewed 920 times
Old 07-27-2006, 12:14 PM
Frank Douglas's Avatar
Frank Douglas Frank Douglas is offline
Cool Maytag 92 Fuel Problem
Picked up a model 92 Maytag at the Adams TN show a couple of weeks ago. Will only run if I keep covering the intake with my hand. Don't believe it has a check ball in the fuel pickup. Could this be the problem? Thanks for any and all advice.
Frank, in hot and HUMID Tennessee
Old 07-27-2006, 05:54 PM
WVCS1958 WVCS1958 is offline
Email Not Working
Default Re: Maytag 92 Fuel Problem
Frank:
If it runs with the air intake closed off (full choke) you have either a significant air leak or you aren't getting enough fuel. I think it would run with or without the check ball if it had the correct air/fuel mixture. I've run one with no check ball for a good number of years only because I didn't know it was missing until I started to take it apart for a cosmetic restoration.
Charlie
Old 07-27-2006, 07:13 PM
Francis Francis is offline
Frank.
Here some sites which show cutouts of the Maytag 92 carburetor:
http://www.oldengine.org/members/allen/cut1.jpg
http://www.oldengine.org/members/allen/cut2.jpg
http://www.oldengine.org/members/allen/cut3.jpg
http://www.oldengine.org/members/allen/cut4.jpg
For the Maytag manual go to this site:
http://www.oldengine.org/docs/Maytag_SM.pdf
Francis
Old 07-27-2006, 10:47 PM
Thanks for the posts, put new gasket on the carb and smeared it with pertoleum jelly so I don't think I have a serious air leak. Think I will take a look at the air valve in the carb next. Thanks for your help.
Frank
Old 07-27-2006, 11:41 PM
Exclamation Re: Maytag 92 Fuel Problem
Frank,
check the air valve, also check the fuel pick up. There should be a check valve, and a screen. Make sure the screen is clean. After that, remove the fuel adjustment neevle, and blow air thru the needle mount, with the pick up tube removed. Clean the entire assembly with carb cleaner, and blow out all passages. Make sure you have clean - fresh (less than 30 days old) fuel at 16-1 ratio - SAE 30 non detergent oil (1 cup/gallon). Re install fuel needle, and turn in until it bottoms.The pointer should be to the extreme right, nearly hitting the tank, when the carb is installed. To start - Fill tank to bottom fo fuel fill therads. Open fuel valve to extreme left (pointer should hit fuel tank lid), and kick over several times. Once engine starts, turn needle until pointer is straight up, and fine tune from there. Unless there is a fuel flow problem, you should never have to choke a 92. Make it a habit to top off engine every time you start it. Be sure to drain tank thoroughly at the end of the show season, and hick oveer engine with fuel valve wide open, to make sure all fuel is out of the engine.
Old 07-29-2006, 06:33 AM
Steve B Steve B is offline
Frank,
Good luck getting 'er running! When I restored my first one I had it rebuilt, ready for paint and decided to run it first. After several failed attempts I gave up and it sat in the shop for a year. Then I had a workday at our house for our EDGE & TA Br. 8 group and we got it running. It's now completely restored and is the strongest running Maytag I have ever seen!
Now I have several 92's in pieces in various states of restoration! Watch out, their addicting!
Francis,
Thank you SO much for that link!!!! I had run across that site some time ago but couldn't remember how to find it again when I needed too! Advanced stages of CRS I guess.
Steve
Old 08-02-2006, 06:50 PM
Live and learn, put a check-ball in the fuel pick-up tube and she runs like a top.
Thanks to all who posted advice.
Frank
Economy Fuel Problem CLowe Antique Gas Engine Discussion 12 11-13-2007 10:32 AM
IHC Fuel Pump Problem lister d Antique Gas Engine Discussion 5 10-14-2007 09:27 PM
MH generator fuel system problem trucker Kohler Generators 2 08-26-2007 06:17 PM
Jaeger/Hercules 2HP fuel problem newuser Antique Gas Engine Discussion 27 03-25-2007 05:15 PM
fuel bleeding problem dcameron Kohler Generators 2 07-13-2006 11:45 PM
