Paint Shop
High Temp Paint
Does anybody know the maximum operating surface temperature of a cast iron air cooled small engine....
this thread has 4 replies and has been viewed 2475 times
Old 07-30-2006, 01:16 PM
Frank Martin Frank Martin is offline
Default High Temp Paint
Does anybody know the maximum operating surface temperature of a cast iron air cooled small engine. I'm not worried about the muffler & exhaust, just the engine itself. I'm trying to figure out what paint to use in this application and I want to pick something that will have adequate heat resistance. The rustolieum high temp paints will take the heat, but the finish is marginal at best and the fuel resistance is the worst I've ever seen, so consequently, I'm looking for something better. Thanks for the help.
Frank
Old 07-30-2006, 08:16 PM
joepro91 joepro91 is offline
Default Re: High Temp Paint
TRy BPS paint from TSC (tractor supply co) it has good gas resistence
Old 07-30-2006, 10:07 PM
Jordan's Avatar
Jordan Jordan is offline
duplicolor high heat good up to 1200 degrees farenheit used it on the head on my stover!
Old 10-03-2006, 07:08 PM
Pacrat Pacrat is offline
If you have a way to heat the parts to 300+ after painting. POR20 works really well. It is thermally hardend, so it needs the heat. NO your wife will not let you use her oven.
Old 05-28-2007, 01:15 AM
dennis gresch dennis gresch is offline
Email Not Working
try to get VHT hi temp paint its a ceramic paint that resists anything it resists heat up to 2000 degrees and it comes in aluminum or cast iron colors
High temp sealant Nubian Onan Generators 11 03-21-2008 05:41 PM
High-Temp paint Mike S Small Air Cooled Gasoline Engines 2 06-16-2005 01:10 PM
Steam engine high temp paint BenneMK Stationary Steam & Traction Engines 0 05-14-2005 04:14 PM
high temp filler? NICK Paint Shop 3 01-24-2002 05:35 PM
High Temp Epoxy John Bailey Antique Engine Archives 2 08-10-2001 08:49 PM
