Jacobsen Model ID?
I picked this Jacobsen engine up yesterday. Can anyone tell me what Model it is? It has a Tillotson...
this thread has 6 replies and has been viewed 859 times
Old 08-06-2006, 09:19 PM
Rake60's Avatar
Rake60 Rake60 is offline
Default Jacobsen Model ID?
It has a Tillotson MT3A carb on it.
Old 08-06-2006, 11:23 PM
Exclamation Re: Jacobsen Model ID?
Looks like an early '50s 321 style engine - rated @21/4 HP. Your particular engine was only made a couple of years, and then the starter was re-designed. This was due to the fact that B&S was planning to sue Jacobsen for patent infringement . The ball and sprag starter on your engine was too close in design to the one made by B&S , and Jacobsen did not want to pay the royalties, so it was scrapped. They are a nice display engine.
Old 08-07-2006, 06:55 PM
Bill Geyer's Avatar
Images: 12
Default Re: Jacobsen Model ID?
Hello All,
Look at the as base of the cylinder, if it bolts to the crankcase, it's a J-100 or J-125. I'm pretty sure a J-100 because of the older sheet metal. Older ones have B-10 carb with built on adaptor, later the MT with separate adaptor.
Hope this helps
Bill
Old 08-07-2006, 08:16 PM
Rake60's Avatar
OK
Well this one has a removable cylinder.
And an MT3A carb with a seperate adaptor.
I havn't pulled the cylinder off yet to clean it out, so I don't know
what the bore size is. It starts and runs, but not great.
Rick
Old 08-07-2006, 08:25 PM
Byron Roberts's Avatar
Byron Roberts Byron Roberts is offline
Rick ::You might not have to tear it apart..The manual we found for the J100 sez clean carbon out of manifold periodically....If it is a J 100..I can scan some pages if you want...HTH..Byron.. At the risk of this getting deleated..I'l see you at LMC..
Old 08-07-2006, 09:31 PM
Rake60's Avatar
Not tear it apart???
I have to tear it apart!
When I was a kid at I had all my Christmas toys broken by
New Years, but I knew exactly how they worked!!!
Rick
Old 08-08-2006, 06:43 PM
Bill Geyer's Avatar
Images: 12
Hey Rake,
I was gonna tell you no! don't tear it down, I'll tell you the bore.
But in the interest of all of the broken Christmas toys, especially the cute little 32 Ford with the visible clear plastic engine that I drilled a hole in and filled with oil. Go ahead tear it apart
Bill
My Jacobsen Houston Garden Tractors / Mowers / Scooters 5 05-03-2008 09:26 AM
Jacobsen Engine Model? ww929 Garden Tractors / Mowers / Scooters 2 04-05-2008 12:21 AM
Jacobsen Engine Model ww929 Garden Tractors / Mowers / Scooters 4 03-23-2008 12:21 PM
Jacobsen Model 62 njbrees Garden Tractors / Mowers / Scooters 2 09-28-2007 10:38 AM
What model of Jacobsen is this? Austen Small Air Cooled Gasoline Engines 3 05-25-2006 11:40 PM
