Need Help with 7.5JB-3CR/2442AB Genset
this thread has 9 replies and has been viewed 3223 times
Old 08-07-2006, 11:55:57 AM
mi002le mi002le is offline
Question Need Help with 7.5JB-3CR/2442AB Genset
Help!
One of my colleagues dropped off an old (circa) 1980 Onan Genset and asked me to look at it. The model number is 7.5JB-3CR/2442AB and the serial number is J790459440. It was pretty hard to read, but I think I got it right.
The first thing I noticed was that it wasn't all there. The output panel with meters and plugs is gone! He said he was able to hook it to his gas grill tank and get it started, but he had to hold the start switch on to keep it running...then he said something appeared to burn up...he wasn't sure what was burning. Now when I move the switch to the start position, nothing happens. I don't see anything obviously burned.
Does anyone know where I might obtain a wiring diagram and operating manual for this unit?
Old 08-07-2006, 02:54:02 PM
Jim Davis Jim Davis is offline
Default Re: Need Help with 7.5JB-3CR/2442AB Genset
http://ebay.com/Onan-JB-JC-Service-Manual
Service manual above.
jamesdavis7@cox.net email me and I will reply with a PDF parts manual
Old 08-21-2006, 10:22:21 AM
Jim;
Thank you for the parts manual and the direct to the operating manual. I purchased one.
I've cleaned out the mouse nests, made repairs to the starter solenoid, the ignition relay and rigged up a fuel line. This weekend, I got the engine running on gasoline...it runs pretty good!
As for the generator, I think I mentioned the output panel is missing. I tested for voltage across both sides of the line...At first I got less than 20 volts...then the voltage came on @ about 150volts per leg and the battery ammeter indicated the system was charging the battery. Then suddenly, it went back to less than 20 volts per leg and the battery is no longer charging.
I'm thinking voltage regulator. Any ideas anyone?
Old 08-22-2006, 03:20:23 AM
BTPost's Avatar
BTPost BTPost is offline
Images: 1
Talking Re: Need Help with 7.5JB-3CR/2442AB Genset
from the Spec, it looks like you have a YD Genend 240/120Vac. I would look
at the Regulator for sure and since the genend is brushless there are no
brushes to check.
Bruce in alaska
Old 09-06-2006, 04:46:25 PM
Bruce in Alaska;
I had a chance to open up the unit last night...there is no flywheel side generator on the unit and I'm kind of at a loss as to where to look for a regulator.
I started it again this afternoon...it's discharging on the DC side and about a 20V output on the AC. It doesn't seem to be getting voltage to the terminal block that supplies power to the PC board.
Any ideas? Anyone else who might be able to help is wecome to chime in.
Old 09-06-2006, 04:52:19 PM
Do you have a printed circuit board located under a square metal cover on top of the generator? If so, this is your automatic voltage regulator.
Old 09-06-2006, 05:01:15 PM
Steve;
Yes I do. What I don't have is a schematic, wiring diagram or anything that let's me know what it's supposed to do. Thsi thing came totally without info and without some of the parts.
Old 09-08-2006, 01:02:52 AM
BTPost's Avatar
Images: 1
What you NEED is the YD Generator & Controls Service Manual...
Onan # 900-0184 available from your local Cummins/Onan Dealers
Parts Department. This is the Gold Standard for ALL YD Genset
Service and Repairs. It also has all the Schematics for all the Control
Systems for any Genset that has a YD Genend. From the sound of
things, your problem is in the Exciter portion of the AVR, as your Output
Power is jumping around, at the same time as the DC Charging Voltage.
Since these windings are both Fixed in the YD, I suspect that you have
a problem in either the Exciter portion of the AVR or in the Fixed Exciter
Winding of the Genend. YOu should try Flashing the Fixed Exciter Winding,
and see if that cures, or temperarily solver the problem.
Bruce in alaska
Old 09-08-2006, 10:19:28 AM
Bruce;
Thank you for the information. I'll see if we have a dealer around here I can get the manual from. I used the info from a previous thread and determined the charging circuit is wired correctly...now if only it will work again...I ain't giving up yet!
Michael
Old 10-09-2006, 07:06:59 PM
Smile Thanks for Help with 7.5JB-3CR/2442AB Genset
I got the unit generating electricity on Sunday! I bought the YD Manual from Cummins MetroPower and used the troubleshooting guides to determine the regulator board was malfunctioning. Bought a new regulator board from Cummins and installed it. Started the unit and adjusted the regulator board as per the instruction in the manual. Was able to get a balanced 124 volts with no load and less than 1 volt drop with 1500 watts on each leg of the output.
I was amazed to see how well it took load and maintained engine speed...it seemed like it could run indefinitely. Now I'm going to outfit it with a protected output panel and then test it to see how much load it can handle when it's hooked up to my house.
Thanks to all for your help and encouragement. I certainly learned a lot.
Help ID Genset richmc Generators & Motors General Discussion 5 10-21-2014 08:27:59 PM
OTC 5BH Genset John Hennig Onan Generators 3 03-23-2005 08:56:51 AM
VW Genset jdunmyer Generators & Motors General Discussion 4 11-03-2004 08:07:45 PM
My M5 Genset Jim Dunmyer Generators & Motors General Discussion 3 09-15-2004 03:47:49 PM
HOL-GAR Genset Mike Ledbeter Generators & Motors General Discussion 0 04-04-2002 07:31:22 PM
