Need info on how Briggs FG tank is mounted
When I got my FG, it had (and still has) a gas tank made from a “juice can”. I’m now looking into...
this thread has 3 replies and has been viewed 692 times
Old 08-17-2006, 08:10 AM
Craig DeShong's Avatar
Craig DeShong Craig DeShong is offline
Images: 140
Question Need info on how Briggs FG tank is mounted
When I got my FG, it had (and still has) a gas tank made from a “juice can”. I’m now looking into replacing it with an authentic (looking) Briggs FG tank to complete the restoration (since the chances of finding an original tank are about zippo). I’ve found a source for a reproduction tank… but they are questioning how the tank is mounted on the engine. I’ve looked at the photos on the www.asecc.com site but they don’t provide the detail I need to have this question answered. I’m hoping this posting will fund it’s way to some of you guys who have an FG with an authentic gas tank… and that one or more of you will respond describing how it is mounted (or much better yet… send a few pictures!). Thanks for any assistance you can provide.
Old 08-17-2006, 09:06 AM
Default Re: Need info on how Briggs FG tank is mounted
Craig,
I do not have an FG , but I do have several FI's which use the same tank mounted the same way. Both take use sheet metal straps which are attached to two studs coming out of each blower housing. ( they are really small round head mechine sodered to the shrouds themselfs) I can take some measurements off my original tank later today. These tanks are reproduced by CPC Reproductions as well.
Good luck with your engine
~ Jonathan
Old 08-18-2006, 08:06 AM
Images: 140
Yea, I’ve corresponded with the CPC Repro folks, and they can make me a tank. The chief problem is that if I buy their tank, I may need to postpone my retirement to pay for it. (All kidding aside… I’m sure they do a great job, and I can see that there is a lot of work in making the tank… their cost is well justified… and they need to make some kind of profit too) but being the thrifty soul I am, and finding myself longer on time and shorter on cash, I’m contemplating trying to fabricate a tank myself. So… if those of you with the FGs and FIs (like Jonathan) could provide some general dimensions (circumference, length, general profile, I’ll get to designing and sniping and silver soldering and see what I can come up with. Thanks.
Old 08-22-2006, 09:05 AM
Craig,
here is what I came up with for measurements
The tank is 9 1/4" long from seam to seam and 11 1/2" from end to end the ends are 4" across, there is a 1/4" solder seam at the end of the cylinder so the ends can be easily soldered on. The tank straps are 1" from end seam and 2 3/4" from center of the cap hole. The cap hole is 1.150" and the drain hole is 1/2" OD the fitting holes are 180 degrees apart. The cylinder is rolled and an a center seam is over lapped and soldered
Hope this helps
~ Jonathan
Briggs WA Gas Tank Jonathan Widelo Small Air Cooled Gasoline Engines 0 06-24-2006 08:47 PM
Briggs WMB Fuel Tank Rake60 Small Air Cooled Gasoline Engines 3 01-26-2006 02:15 AM
Info for a gas tank on a 4.5 hp Jumbo K.Watkins Antique Gas Engine Discussion 0 05-03-2005 11:00 PM
Briggs Model Y -- Fuel Tank Jim Tremble Antique Engine Archives 3 03-08-2003 09:31 AM
Briggs Model U with Under Carb Gas Tank Mike in NC Antique Engine Archives 3 03-01-2003 04:21 PM
