| Oil Field Engines A gathering place for OFES members otherwise known as "Oafs". Basically, if you like "BIG OLD GREASY RUSTY OIL FIELD ENGINES, you're in the right place. Founded by Russell Farmer. |
regulatorI have read in old posts that a high and low pressure regulator are used on a Reid 15. What is the...this thread has 1 replies and has been viewed 1120 times
I have read in old posts that a high and low pressure regulator are used on a Reid 15. What is the purpose of the high pressure one? Also, I picked up a Ford T coil that looks good except for the rust on the top. Any suggestions on how to de rust these tiny parts? Thanks, Dan
Some use a High pressure regulator instead of a needle valve for the hot tube burner.
The coil? I taped up the wood and sand blasted carefully until I could get the nuts off, then blasted each part. I have 3 of them that have all brass parts.
| 7.5JB Propane Regulator | JBittnerSr | Onan Generators | 4 | 10-11-2007 08:18 AM |
| Need help with voltage regulator | oldtool53 | Generators & Motors General Discussion | 13 | 12-11-2006 09:04 PM |
| Generac regulator | Andre Blanchard | Generac Generators (SEARS, etc.) | 2 | 02-06-2006 11:34 AM |
| LP Gas Regulator | Dave_T | Generators & Motors General Discussion | 7 | 12-07-2005 06:02 PM |
| PROPANE REGULATOR | H PRICE | Antique Engine Archives | 1 | 07-15-2000 01:02 PM |
