Wico EK sparks where it shouldn't!
I'm working on an EK that's got me stumped. I've repaired quite a few of these things but never had...
this thread has 6 replies and has been viewed 986 times
Old 08-19-2006, 02:19 PM
Nick's Avatar
Nick Nick is offline
Fuller & Johnson Mfg. Co.
Images: 34
Exclamation Wico EK sparks where it shouldn't!
I'm working on an EK that's got me stumped. I've repaired quite a few of these things but never had this happen. When I trip the mag I get a little spark in my test lead but a nice blue on across the points! Mag has been stripped down, cleaned and assembled with all new insulation. I tripple checked for any shorts but found none. Also tripple checked my wires, they're all good and going to the right spots. Condenser is brand new, mag has been charged on a very powerful charger. Points are set 3/32 for type 2 drive and are in great shape. Nothing binds, there is no oil or grease slopped all over the place. I'm out of ideas here. Looking things over I see nothing out of place or wrong.
He who sees the other first already has half the victory
visit the Fuller & Johnson Mfg. Co.
Old 08-19-2006, 03:57 PM
Francis Francis is offline
Default Re: Wico EK sparks where it shouldn't!
Nick,
In case you don't have a copy of the Wico EK maintenance manual, I have it stored on my computer. If you want a copy I will gladly send a copy to you. Since I don't know how to send an attachment to this message, I will need your email address.
If anyone else needing a copy of the Wico EK manual, I will also send you a copy. However, I will also need your email address.
Francis
FRM8198@aol.com
Old 08-19-2006, 11:33 PM
Exclamation Re: Wico EK sparks where it shouldn't!
sounds like either you have a bad coil, or a defective condenser. Have you checked the condenser out? Andrew
Old 08-20-2006, 12:25 AM
Brand new condensors can be just as defective as those that are older than dirt.
Harry's Old Engine Site My Videos
Old 08-20-2006, 03:34 PM
KeithW's Avatar
KeithW KeithW is offline
Smile Re: Wico EK sparks where it shouldn't!
Hello all,
Just got a copy of the Wico manual from Francis. Spent about an hour setting mine up properly. What a differance! My Hercules that I just put the piston in has always been a little fussy to start, not horrable but just a little touchy. After setting the mag up it almost jumped to life. Hit on the first pull through, and, as soon as I retarded the timing fired right off. Highly reccomended reading. Thanks again Francis .
keithw
Old 08-20-2006, 05:00 PM
Nick's Avatar
Images: 34
I swapped the condenser out with another new 1 and same problem. Andrew you might b right about a bad coil although I've never had 1 that was bad behave like this before. 1st time 4 everything though...
Old 08-22-2006, 01:22 AM
MarylandSteam MarylandSteam is offline
How far is the gap on your test lead? if too far it will jump across inside.
Moline Universal help no sparks? William Engelmann Antique Tractors - Old Iron Lugs, Cleats and Tracks 3 08-02-2006 05:16 AM
wico pr David Scott Magnetos, Ignition Coils and Spark Plugs 0 05-08-2006 10:38 PM
wico ek ron brown Antique Engine Archives 2 12-16-2003 07:29 PM
Wico mag Jesse Zilafro Antique Engine Archives 1 09-22-2002 08:46 AM
Wico EK Mag Help Brad Franken Antique Engine Archives 10 09-02-2002 03:18 PM
