Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engine Collectibles
Maytag model 19 update
Well guys, I have the engine torn down, everthing came apart easy, the piston was no problem after...
this thread has 11 replies and has been viewed 675 times
Old 08-19-2006, 02:30 PM
Sean B. Sean B. is offline
Default Maytag model 19 update
Well guys, I have the engine torn down, everthing came apart easy, the piston was no problem after soaking for a while, and using the hyd method. The only thing that has me stumped is the removal of the starter clutch body, it looks like it has a set screw in on side and a pin sticking out the other side. But the set screw wont turn, and I dont want to strip it out! Now here is the main thing I need to decide... If it is a model 19, sould I worry about the exact paint color, and using all the original hardware? I had the thought of using chrome or perhaps stainless bolts, polishing the flywheel, using the older black and yellow plug wire that you can buy in bulk to dress it up a little, or should it go back together exactly as it was built????? You guys help me decide please!!!!! I look foward to everyones input
Old 08-19-2006, 03:16 PM
Francis Francis is offline
Default Re: Maytag model 19 update
Here is the web site for the Maytag manual:
http://www.oldengine.org/docs/Maytag_SM.pdf
Francis
Old 08-19-2006, 03:18 PM
Dan Baalman Dan Baalman is offline
The starter clutch hub attaches to the crankshaft with a tapered pin. The one end is usually split so it can be spread out a bit to prevent is comming loose. You drive it out from the split side as it tapers from this side. Color is your preference. Would have been dark green originally.
Old 08-19-2006, 11:39 PM
Exclamation Re: Maytag model 19 update
The tapered set pin is relatively soft steel. Squeeze the split ends together, and drive it out with a pin punch, slightly smaller OD, and centered on the pin. Don't hammer directly on the pin with a hammer - it will mushroom, and then you will have to drill it out If it mushrooms, you will have a RPA getting it out. When you install a new pin, make sure the taper on the crank, and the starter match up!
Old 08-20-2006, 01:04 AM
Ray Cardoza's Avatar
Ray Cardoza Ray Cardoza is online now
A friend of mine picked up a mdl 82 single cylinder and is wondering what the year of build is heres the #551615 thanks
Old 08-20-2006, 06:51 AM
Ray,
Here is a web site with Maytag serial numbers:
http://www.asecc.com/data/maytagdata2.html
Francis
Old 08-21-2006, 01:01 AM
thanks for the link looks to be built between 1927-1937
Old 08-21-2006, 02:05 AM
Question Re: Maytag model 19 update
Ray, the dates on your last post co-incide with the model 92, the 82 single bearing, I believe was earlier than '27
Old 08-21-2006, 10:56 AM
Tom S's Avatar
Tom S Tom S is offline
It was built in May of 1934
Sean,
Don't be afraid to retore it the way You want to! Post pics when you are done!
Tom
Old 08-21-2006, 06:02 PM
ok. I'll let the kid know that it might not be a 82 probably the 92. thanks
Old 08-21-2006, 06:03 PM
Sean,
Tom
Thanks for the info there.
Old 08-21-2006, 11:03 PM
Thye 92 was a dual bearing engine, with the kick starter on one side it, and the flywheel and takeoff on the other. The 82, single bearing was a rope start, only the flywheel end of the crank came out of the crankcase!
Maytag Model 82 MaytagRepairMan Maytag Engine Collectibles 3 08-18-2007 02:47 AM
Maytag model 92 Alex F Antique Gas Engine Discussion 4 03-12-2007 04:06 AM
Maytag Model 31 Chad Schlifke Maytag Engine Collectibles 10 12-12-2003 12:57 PM
Maytag model 72 Robert Miller - Tucson Antique Engine Archives 4 10-03-2001 09:36 PM
Maytag Model 31 JW(NC) Antique Engine Archives 5 10-02-2001 10:08 AM
