DJC low voltage, flash the field?
My 12K DJC is putting out 37 volts on each leg. And the DC ammeter shows negative 1.5 amps. I...
this thread has 1 replies and has been viewed 1367 times
Old 08-21-2006, 10:45 AM
rich9499 rich9499 is offline
Question DJC low voltage, flash the field?
My 12K DJC is putting out 37 volts on each leg. And the DC ammeter shows negative 1.5 amps. I picked it up in the winter, let is set a few months and got it running and working ok in the spring. One day it was working fine and few days’ later, low voltage. It has no voltage adjustment (R22) control. The VR21 is labeled YD regulator 300 1404(D) .
I’m thinking it’s probably the regulator, but the procedure for regulator checkout looks a bit overwhelming to me. So I’m fishing for something else to check before attempting it. In the section about flashing the field it says check residual voltage at terminals 1 and 2 should be at least 20 VAC. I measure only 11.4. The thing that bugs me is that there were only a few days between when it was working ok and when it started producing low voltage. Mostly what I’ve seen about flashing the field is after it’s been sitting in a field for a few years or something.
Also about flashing, the manual says to use a 6 VDC battery and put a 12 amp, 300v diode in the circuit. I don’t see that mentioned in on-line discussions. Is it worth the effort? Or can I just hit it for second with 12 Volts as I’ve seen suggested.
There are so many smart people on this forum, I guess I’m hoping my symptoms of 37 volts and negative DC amps will trigger a… Oh that’s commonly “a something” from someone. Thanks for your time.
Model and Spec: 12 ODJC 3CE/2236AA
Serial No: 0374 764922
Old 08-21-2006, 06:26 PM
Billy J Shafer's Avatar
Default Re: DJC low voltage, flash the field?
I would say you have a bad regulator.I have seen them work fine one day one day and stop the next.I have one I can send you brand new never been opened.If it works we can talk about price.
Field Flash Diode GlobalEnergies Onan Generators 1 03-15-2007 09:00 PM
simple field voltage fine regulation armandh Generators & Motors General Discussion 1 08-31-2006 08:00 PM
Exciting the field/ Flash the field?? Gary Bright Generators & Motors General Discussion 1 03-18-2004 09:46 PM
Field voltage for Gary Fischer Generators & Motors General Discussion 0 04-06-2002 12:45 PM
What does 'Manual Field Flash' mean ? Jorrit Generators & Motors General Discussion 4 06-16-2001 06:06 AM
