1" Case from Cole's casting set
This is one of my earliest steam engines. I purchased the complete casting kit from Cole's in 1973....
this thread has 7 replies and has been viewed 1309 times
Old 08-23-2006, 05:24 PM
gbritnell gbritnell is online now
Default 1" Case from Cole's casting set
This is one of my earliest steam engines. I purchased the complete casting kit from Cole's in 1973. I have about 1 year in building time. This winter I'm going to go over the whole engine and refine some of the components and repaint and stripe the complete engine. It has been run on steam a handful of times by using a propane burner that I built for it. Lately it just gets run on compressed air. All of the components operate properly, the water pump, the governor, the differential gearing, the clutch etc.
gbritnell
Old 08-23-2006, 09:04 PM
Glenn Gieszler Glenn Gieszler is offline
Images: 101
Default Re: 1" Case from Cole's casting set
Terrific Job!
I would like to thank you for sharing your accomplishment with others, Can you answer a few questions about the kit. I am wondering how much of this is available and how many pieces you had to fabricate, and if you had to either purchase or make a lot of tools for this project, I have seen their list but seems confusing like you have to buy everything seperately, and your boiler looks fantastic do they provide drawings to fabricate or is that part assembled, Thanks Again for sharing.
Old 08-23-2006, 09:57 PM
Thanks Glen,
When I bought it you could buy it in sections or as a complete kit. I haven't seen their catalog for awhile so I don't know how they are selling it now. The boiler came with the following pieces: a tube for the boiler shell, the front head and backhead were flanged pieces as was the front of the firebox that wraps around the boiler, sheet copper for the boiler and firebox wrapper sheets, copper tubing for the flues, copper bar for the stays, copper rivets and bronze castings for the smokebox cover, firebox door and the smokestack. The drawings can be purchased seperately and are quite complete. I didn't need any special tools other than the tools I already have in my machine shop. Unless you mean a lathe and a milling machine. Most of the castings are quite good but some of the smaller ones have quite a bit of burn in which in casting terms means that they have a rough surface texture. If you are handy as a machinist you could fabricate the small parts. When I purchased the kit it came with all of the finished gears so you wouldn't need to cut gears or look for them. Probably the hardest part wash fabricating the operators platform along with the water tanks. It's formed from a large piece of brass sheet and I didn't have sheet metal tools so I had to make a small brake for bending it up. I hope this answered your questions. If you have any more please don't hesitate to ask.
gbritnell
Old 08-24-2006, 09:01 PM
Colin's Avatar
Colin Colin is offline
Images: 135
neat little engine! look like a 65 with a cast stack like a 75. i bet its fun to play with. i can help with paint colors and striping if you'd like. have fun
Old 08-24-2006, 09:15 PM
Tom Sampson's Avatar
Tom Sampson Tom Sampson is offline
Images: 61
Great Looking Case. Nice Job
Tom
Old 08-25-2006, 01:23 PM
dhopfinsd dhopfinsd is offline
Nice engine.
Been dreaming about building one of these for 40 years and I'm only 45.
Is Coles still in business and making the castings?
If so, does Coles have a website or mail address?
Don Hopf
Old 08-25-2006, 04:41 PM
Thanks Don, Tom and Colin. Yes, Coles is still in business. The original business that was being operated by Charlie Cole's daughter Betty was sold a number of years ago. They have a current catalog and here is the link to their website.
http://colespowermodels.com/
gbritnell
Old 09-02-2006, 01:22 AM
Randall Marquis Randall Marquis is offline
Coles Power Models is located at 5539 Riverton Ave. North Hollywood, Calif. 91601 (818)762-1734. You do very nice work. I'm currently working on Cole's Corliss Engine.
Case "Heating Surface Area" Rick Strobel Stationary Steam & Traction Engines 34 01-07-2008 09:54 AM
Cole's Large Hit & Miss actionhac Scale Model Engineering 3 11-23-2007 01:53 PM
Case 25 & 75 "Montana Specials" Chuck Sindelar Stationary Steam & Traction Engines 92 11-01-2006 10:33 AM
"Case" 6 - 18 HP. portable at shows? Richard Miller Stationary Steam & Traction Engines 21 01-07-2006 12:30 AM
"Case" smokebox handhole question Richard Miller Stationary Steam & Traction Engines 21 01-03-2006 01:20 AM
