Go Back   SmokStak > SmokStak® General Discussion > Alternative Fuels
Alternative Fuels
Coleman Fuel works great!
Recently, there have been a few posts regarding alternative fuels for our old iron. So I did some...
this thread has 12 replies and has been viewed 2604 times
Old 08-26-2006, 05:35 PM
WheelSpinner WheelSpinner is offline
Thumbs up Coleman Fuel works great!
Recently, there have been a few posts regarding alternative fuels for our old iron. So I did some research in the archives and came across a few saying that coleman fuel made these old engines run better. I decided to give it a shot and can now say that Coleman fuel does indeed seem to make my FM-ZA engine run better. I am not convinced that it started any easier but it did run slower and it didnt have as loud as a bark. It also didnt smell as bad out the exhaust. So if you are inclined to try it, I think you will be pleased.
Joe
Old 08-26-2006, 05:51 PM
Ackman's Avatar
Ackman Ackman is offline
Images: 22
Default Re: Coleman Fuel works great!
That's great to hear, but Coleman Fuel is at least $5 a gallon...even gas is cheaper!!
Everyone is born right-handed; Only the greatest can overcome it!!!
Old 08-26-2006, 07:04 PM
Randy,
Yeah, tell me about it, my gallon cost about $8 but I only run my engine for shows and amusement so I figure if I burn a gallon a year, the extra $ is worth the improvement. (IMHO) Wouldnt use it if I was running the engine for power instead of enjoyment.
Joe
Old 08-26-2006, 07:18 PM
BDMelon BDMelon is offline
Images: 11
. walmart has same stuff , but call Ozark trial latern fuel about 1.50 cheaper i have been using it for 2 years now, & will not put pump gas in my h&m engines any more, Heck of lot less fouled plugs & ignitors , engines does run a tad cooler , but when storing engines for winter , plug off
vents, . or the fuel evaps out, but it does go bad either!! yea i know put
stabil in it if using pump fuel. but have you been around a engine when it runs with stabil in it
wow what a smell just my 2 cent, & this thread has been on before many times. so this is end from here--------lol
BDmelon
Old 08-26-2006, 07:38 PM
John Newman, Jr.'s Avatar
How long will a sealed can of Coleman fuel last on the shelf? I inheirited about 20 gals when my father passed away. He went in Oct, '98, but had started stock piling some things in preperation for the predicted Y2K melt down. He didn't even get to see it 'Not Happen'.....
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 08-26-2006, 07:55 PM
Images: 11
run it john should be ok, lol
Brian
Old 08-26-2006, 08:12 PM
Tom Sampson's Avatar
Tom Sampson Tom Sampson is offline
Images: 61
Has anyone tried 100 octane low lead Avgas? We have used it in some engines and a whizzer motor bike. It doesn't go bad and is around $4.00 a Gal.
Tom
Old 08-26-2006, 08:34 PM
Doug Kimball's Avatar
Images: 62
I was using av gas for a while because if in a plane the FAA allows you to store it for up to five years. The regular pump gas was going bad after one winter. I figured if ok in a plane for 5 years should last several in an old engine. Problem was that in hot weather engines could be a bear to start. Since switching to Ozark Trails & a capful of Marvel Mystery oil the starting problem in hot weather is gone.
Old 08-26-2006, 09:46 PM
Patrick McNallen Patrick McNallen is offline
I really like the Coleman-type fuel for old low compression engines. It's overpriced, but what isn't? As for how long it will last in storage, I don't know, but I think it will last a very long time. I have never had any of it go bad, and I've had some around here for over a year in a vented fuel tank. You don't want to store any gasoline or similar hydrocarbon liquids in any kind of container that will allow sunlight into it. I'm sure that leaded Avgas would also be fine for an old engine. I think you could get it in 80 octane, which is way more than enough. I'm not sure if the old low compression, low speed engines would develop enough combustion chamber heat and pressure for the scavenging agents in leaded Avgas to work properly, but I doubt if it would be much of a problem. I have never had a problem with "lead fouling" in any kind of engine. Leaded Avgas would probably be the best fuel you could ever get for an older Briggs-type engine or any of the older Wisconsins. These higher speed, higher compression, air-cooled engines would benefit from the lead and they probably need about 80 + octane fuel if they are running at or near rated load, especially in hot weather and/or at low altitudes.
Old 08-26-2006, 10:06 PM
Frank Douglas's Avatar
Frank Douglas Frank Douglas is offline
I have been using Ozark Trail fuel in my model hit and miss engine for about 4 years. Works great! Course I'm puting a little weed-eater oil in it for the model engine. Think I've had the gallon I'm working on for at least 2 years, maybe more, seems to be good as ever.
Frank
Old 08-26-2006, 11:04 PM
Terry Beasley's Avatar
Terry Beasley Terry Beasley is online now
I seem to remember reading somewhere that the Coleman brand had some type of fiberous trash in it and that the Ozark brand from Wal Mart was a lot cleaner.
Old 08-26-2006, 11:20 PM
Terry,
Don't know what you were reading but the orifice in lantern generators is a whole lot smaller than anything found in a carburetor. I've never had problems with Coleman fuel in any of my lanterns or camp stoves.
Bill
Old 08-27-2006, 12:17 AM
Exclamation Re: Coleman Fuel works great!
Only problem with coleman white gas , is it is hydroscopic - it attracts moisture, and it leaves a corrosive residue in the combustion chamber, if you do not shut off fuel when shutting your engine down. When done for the year, run the engine totally out of gas, or fill the tank to tippy top. Run engine, and shut off fuel at the adjustment needle, while engine is coasting down, spray 10W-30 oil into intake. this will coat cylender and valve surfaces with oil, and protect them from corrosion. When engine stops, yun the puston against compression for a few seconds, to make sure both valves are closed. This will ensure that the cylinder is oil coated, and that the valves are shut. it will keep water out of the cylender (mice too!)
Fuel tank for Coleman PM 1500 portable generator John A Generators & Motors General Discussion 2 07-15-2007 08:05 AM
Coleman Fuel ethenol or methenol Johnny Williams Antique Gas Engine Discussion 18 04-09-2007 09:04 PM
Tank sealers/ Coleman fuel Eric McKenna Antique Gas Engine Discussion 3 12-11-2006 11:58 AM
IHC Famous 4 HP Horizontal running on Coleman fuel. Harry Antique Gas Engine Discussion 11 12-04-2006 06:22 AM
Great hobby with great people Dan Baalman Antique Gas Engine Discussion 19 01-16-2006 04:04 PM
