Compressor ID helpJust got a old air compressor, its a JD Cochin MFG on the pump. V twin with one cylinder bigger...this thread has 1 replies and has been viewed 834 times
Just got a old air compressor, its a JD Cochin MFG on the pump. V twin with one cylinder bigger than other. Made 10/57. Has anyone heard of it? Would like to find a manual for it or whatever I can find about it. The tank looks to be about 100-150 gal size. Its missing elc motor the everything else on it is like new. Thanks for your help.
Although I don't have details, I can give you some general info: Your compressor is a 2 stage unit - the large cylinder compresses the air to about 85 PSI, the air usually is run thru some type of cooler (a coil in front of a fan), and then the second - smaller cylender compresses that air up to tank pressure (usually between 125 and 150 PSI). I think you will need at least a 1 HP motor, if not larger.
| Air Compressor | Tilinghast | Antique Gas Engine Discussion | 2 | 04-24-2005 07:11 PM |
| Need help with an air compressor | Joseph Musser | Antique Engine Archives | 2 | 11-01-2004 07:16 PM |
| Mod A compressor | E. Rothwell | Antique Engine Archives | 0 | 04-04-2004 06:55 PM |
| compressor? | L.D. | Antique Engine Archives | 0 | 10-07-2002 11:19 AM |
| IR Compressor | Ken K | Antique Engine Archives | 2 | 06-16-2002 11:29 AM |
