Parts Catalog by sizes?
A while back there was a thread concerning a catalog that NAPA has with engine parts ie: valves by...
this thread has 3 replies and has been viewed 715 times
Old 07-23-2001, 06:44 PM
Denny Foster
Default Parts Catalog by sizes?
A while back there was a thread concerning a catalog that NAPA has with engine parts ie: valves by sizes rather than application, does anyone out there know the name of this catalog when I asked the local NAPA I got a reaction very much like a mule staring at a new gate!
Thanks!!! Denny
Old 07-24-2001, 05:31 PM
Marv. Weber
Default Re: Parts Catalog by sizes?
Denny-When I worked in a auto parts store many years ago (long before computer catalogues) they were called progressive size charts. It could be that in the modern computer age they don't exist anymore. I would suggest that you find a good automotive machine shop and ask there as they would have more use for such a list.
Marv. Weber
Old 07-24-2001, 06:35 PM
Dale Russell
Denny, I don't know about NAPA but O"RIELLY'S has a book on small engines by PRIME LINE. It has dim. Of valves if that is what you are looking for
Old 07-25-2001, 12:31 AM
Bill Garman
Denny: I mentioned the NAPA books a while back. I am the mechanic for a fair sized construction company, and spend thousands of $s yearly at NAPA, so they work with me a lot, and I do get special favors. The books do exhist, as I am looking at a pile of them right now, so here goes. The book SPEC-3N (May 1995)shows the NAPA numbers for valves by size, it then has valve springs,and inserts, pushrods, valve guides, valve seats, expansion plugs, piston pins, piston pin bushings, pistons, and cylinder sleves; all in progressive sizes, and all with NAPA part numbers.
Weatherly index 020 Catalog no. PR-020-98 is a Perfect Circle book used by NAPA, listing piston rings in progressive sizes. Hope this helps. If you are looking for a specific item by size contact me via E-mail and allow me a couple of days. I will see what I can do.
Stover Piston Sizes bruce burgess Antique Gas Engine Discussion 1 11-28-2007 09:50 PM
drill sizes Eric Schultz Antique Gas Engine Discussion 23 02-26-2007 10:21 PM
D4 cat parts catalog-Traxcavator PL. Donald A Smith Antique Tractor Talk 2 02-16-2007 10:15 AM
See how many wrench sizes can you can name? Pat Barrett Antique Engine Archives 10 09-17-2004 11:21 PM
Sizes for a 3hp FMZ cart Rob Charles Antique Engine Archives 1 08-29-2003 01:53 PM
