Webster Tripolar with weak spark
Hello Everyone, I recently bought a new Bamford engine fitted with a Webster mag. The previous...
this thread has 1 replies and has been viewed 1298 times
Old 08-29-2006, 04:56 PM
RobertAdams RobertAdams is offline
Default Webster Tripolar with weak spark
Hello Everyone,
I recently bought a new Bamford engine fitted with a Webster mag. The previous owner spent some time refurbishing the mag and fitted new coils and had the mag re-magnatized. Unfortunatley the spark still seems weak. The engine will fire a few times an then gives up. On battery and coil the engine runs fine. Any tips as to what might be the problem. I though these mags were supposed to be idiot proof!
Thanks in advance!
Old 08-29-2006, 06:05 PM
Exclamation Re: Webster Tripolar with weak spark
Low tension spark: electrically simple - mechanically complicated! Everything has to be adjusted perfectly, and there cannot be much wear on the assembly, or it will not perform well. There are several posts on set up on the webster, and Doc Shulsters (sic)book (available from advertisers here on the stak) is also excellant, on set up.
Webster Tripolar Magneto problems actionhac Antique Gas Engine Discussion 4 09-16-2007 07:45 PM
Weak Webster Mag Smokey Stover Magnetos, Ignition Coils and Spark Plugs 5 06-11-2007 04:48 PM
LB Mag weak spark Bill Schaller Antique Engine Archives 7 08-12-2004 07:33 PM
Webster Tripolar and bracket hartv Antique Engine Archives 2 06-12-2004 06:20 PM
Weak spark - Help Nathan Antique Engine Archives 2 03-09-2000 01:32 PM
