Mounting my winch
My winch probably weighs 100 lbs. It is the antique Beebe Brothers winch shown here: ...
this thread has 8 replies and has been viewed 2009 times
Old 08-29-2006, 11:27 PM
Tim Claremont's Avatar
Tim Claremont Tim Claremont is offline
Images: 14
Default Mounting my winch
http://www.grandamregistry.com/winch.jpg
I want to mount it on the tongue section of my trailer, and therefore will be having a platform welded onto the trailer. My question is, how thick of a mount do I need?
I plan on leaving the winch on the platform shown in the picture above. Would a solid piece of steel provide any advantage over just a crossbar that the winch will bolt to? I question this because my weight distributing hitch will need to bolt to the frame, and a solid sheet of steel would get in the way, whereas a crossbar might not.
Figure I will be winching loads up to 1500 lbs, but they will be on wheels.
Is there a rule of thumb other than 'bigger is better"?
Old 08-30-2006, 12:43 AM
Franzİ Franzİ is offline
Registered 0
Default Re: Mounting my winch
Mounbt the winch on the curb/front corner of the trailer deck, and use a snatch block in the center of the trailer. That way, you are pulling across the deck, rather than putting downforce on the front of the deck with the winch cable.
OR, you can mount the winch in the center of the deck nose, and make a long handle for the crank.
OR you can mount the winch under the deck, make a long cranking handle, and a roller to get the cable over the nose of the deck.
Don't forget to install tiedown rings across the nose so you can use a snatch block at the load, and cut the winching pull in half. Also, a tiedown for a snatch block at the back of the deck comes in real handy unloading.
Having done more than a few, I preferr the winch in the center of the deck nose with plenty of tiedown rings on all edges of the deck.
Old 08-30-2006, 03:08 PM
Bill Wehrman Bill Wehrman is offline
Defective Email Address
I thought this was a family site!!!
Old 08-30-2006, 09:33 PM
Images: 14
Here is a better picture of what I am up against:
http://www.grandamregistry.com/winch2.jpg
I think this arrangement is what I will wind up with.
A piece of steel to replace the 2x4 and I think all will be well.
It puts the brackets for the weight distributing hitch where they need to be, and leaves enough room to turn the crank handle without busting your knuckes.
It also gives me a good amount of tongue weight!
By the way, I found a patent date under a bunch of crud. 1928. So, it is 'period correct' anyway.
Old 08-31-2006, 12:31 AM
Registered 0
Little cutting & a little welding, you could turn that base into a nice tool box, and strengthen it as well.
I don't think the 2x4 is gonna do the job though, even if you glue it into the frame with Liquid Nails.
Old 08-31-2006, 08:39 PM
Images: 14
Franz, can you hook me up with one of these in diamondplate or equivalent?
http://www.grandamregistry.com/plate.jpg
Old 08-31-2006, 10:46 PM
Registered 0
Diamond plate inventory is low. Diamond plate is expensive, but I may have some 10 ga or 3/16 hrs plate.
No extra charge for mill scale or rust.
Old 08-31-2006, 11:14 PM
Images: 14
Shouldn't take any more than a few minutes to spin one of these off...no?
Old 09-01-2006, 02:35 PM
Registered 0
I don't do time estimates Tim, ain't real sure how fast you can push a hacksaw.
Winch advice Frank Y Trucks, Trailers and Hauling for Shows 24 11-02-2006 12:27 PM
Winch mounts JCullom Trucks, Trailers and Hauling for Shows 3 09-25-2005 12:17 AM
Need advice on a winch Chris Kirk Trucks, Trailers and Hauling for Shows 11 10-16-2004 09:16 PM
Winch of interest Arnold Stationary Steam & Traction Engines 0 07-15-2004 08:46 PM
Winch or Slave(s)?? Jeff Holbrook Antique Engine Archives 10 05-13-2004 10:08 PM
