Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engine Collectibles
Maytag Model 92M Muffler Adapter
I just finished up my first Maytag. I wanted to put a muffler on it, so I fabricated this...
this thread has 2 replies and has been viewed 678 times
Old 09-05-2006, 10:01 PM
Rake60's Avatar
Rake60 Rake60 is offline
Default Maytag Model 92M Muffler Adapter
I wanted to put a muffler on it, so I fabricated this adapter.
I used the engine exhaust flange as a template and made a matching
flange out of 1/4" thick flat stock. Drilled the holes first, then rough cut it
out in a diamond shape. Then I finished the shape on a bench grinder.
I picked up a 3/4" merchant coupler for $1.10 and welded it to the flange.
I ended up with this.
It doesn't look too bad for being made with a drill press and grinder, and it
sounds OK. Here's a link to a video of it running if anyone is interested.
http://www.rake60.com/photogallery/1...M_Running.mpeg
I still need the pulley and decals. Watching eBay again, or is that still???
Rick
Old 09-06-2006, 09:54 PM
Scott Wenrich Scott Wenrich is offline
Images: 139
Default Re: Maytag Model 92M Muffler Adapter
Great job,Rick.Kinda inspires me to try my hand at welding.I have a mig welder but i've only 'played' with it a couple of times and ended up burning through a gas tank! But i guess tanks aren't made to be welded!LOL!
I bought a repro maytag ball tye muffler on ebay for my 92 so i would imagine you could find the pulley you are looking for on ebay.
Scott
Old 09-07-2006, 01:20 PM
Rake60's Avatar
Trust me Scott, I'm a much better machinist than a welder.
My welder is a little 110 Volt flux core. There is as much, if not more,
grinding time in my welds as there is welding time. But with practice and
pacience you will end up with good results. The real welders at
the shop I work for tell me: "Push the puddle, keep it steady and even"
I'm working on it...
JD Model D muffler David Parfitt Antique Tractors - Old Iron Lugs, Cleats and Tracks 2 03-24-2008 08:17 AM
Cat D8H 24v Starter adapter needed Don Smith Antique Tractor Talk 2 03-06-2008 09:52 AM
Maytag Model 82 MaytagRepairMan Maytag Engine Collectibles 3 08-18-2007 02:47 AM
cck oil filter adapter KC135R Onan Generators 3 04-12-2007 07:41 PM
Briggs Model 14 Muffler Thread Repair Jim Metzger Small Air Cooled Gasoline Engines 15 10-12-2006 05:05 PM
