Welding Shop
P & H Welder (WNP2001B) info, manual needed.
I just obtrained an old P&H welder. It has an Onan CCK engine. It runs pretty well. I haven't...
this thread has 16 replies and has been viewed 3994 times
Old 09-17-2006, 11:37 AM
Bill Cross
Default P & H Welder (WNP2001B) info, manual needed.
I just obtrained an old P&H welder. It has an Onan CCK engine. It runs pretty well. I haven't yet tried to weld with it, but the 110 ac works. From the plate is listed WNP2001B; 6CCK-331E/4325J; 66C897064; specification No 2100 1100.
Any info or source of parts or manuals would be greatly appreciated.
Bill Cross (wcross@pennswoods.net)
Old 09-17-2006, 02:41 PM
MCanady's Avatar
MCanady MCanady is offline
Default Re: P & H Welder (WNP2001B) info, manual needed.
Bill I have a P&H welder also and I haven't found a owner's manual either. Mine is powered by a 4 cylinder Continental Flat head engine. If anybody has Information or helpful ideas, I also am in need of information. Merton
Old 09-15-2007, 07:21 PM
Arthur Arthur is offline
MCanady, imagine my surprise running across your post. I was looking at a P&H welder just today,the first one I have seen since I was a welder with New Bern shipyard in 1964. If I can figure a way to sneak it home without Frankie seeing me, I'm planning to pick it up. It is also a 3 kW ac 60 cy out put. It has some problems too.
When you get time stop by and we'll talk a little bit. I have a new e mail address now that I'm with EBARQ . Regards Arthur
Old 11-08-2007, 08:34 AM
Scott Heafield Scott Heafield is offline
I have a lincoln sa200 1981 or so with a continental f163 flathead 4cyl . I also cant find a service manual please help!!!!!!
Old 12-03-2007, 09:33 AM
TommyA5 TommyA5 is offline
I recently bought a P & H WNG-200B engine driven welder. It isn't running at this time but I'm working on it. There isn't a tag on the engine but from everything found on the web so far points to a Contenintal F163 just as was used on the SA200 welders. Because it was used on the Lincolns there are still parts available as well as manuals located on the lincoln web site. Maybe this will help with some of the questions.
Old 12-14-2007, 02:41 PM
m_thompson m_thompson is online now
I also have a P&H with an Onan engine. I also have a spare generator, resistor set, and some of the engine.
Old 01-01-2008, 09:00 PM
Hello Thompson, just checking to see if you might let some of the spare generator and engine parts go ? Mine is Onan opposed piston powered and like me getting up in years. I thought I had the tag info. handy, but can't find it right now. Happy new year, and thanks in advance, Arthur
Old 01-09-2008, 01:41 PM
Authur, m_thompson do either of you have a wiring diagram or welder manual for your P&H? I was able to get an engine overhaul manual from the Wisconsin engine site for my Continental F140.
Old 01-10-2008, 10:47 PM
Hello Tommy, I haven't tried to find anything for my P&H yet. I'm pretty busy with other toys at the present. I know mine will need more than TLC , but thats all I know about it. It does have the 2 cyl, opposed engine. If I find something that will help, I'll let you know. Arthur
Old 01-11-2008, 07:49 AM
Arthur Sorry about misspelling your name.Just to let you know, I have conducted several searches on the web for info on the P&H welder with no results. About the only way I see getting this info is from someone who still has it in hard copy. There really isn't a lot to worry the wiring is fairly simple, I just was curious.
Old 01-12-2008, 06:59 PM
I would be happy to give the spares to a good home. Shipping might be a problem though
Old 01-23-2008, 11:06 PM
Thanks Thompson, You are right about the shipping costs, They are sure to be in this area . If I was closer , I would run by and see what you had. I appreciate your response, Arthur
Old 02-27-2008, 01:18 AM
FlyingWrench FlyingWrench is offline
Are you still looking for info on the P&H welder?
Steve
piperpilot55r@aol.com
Old 02-27-2008, 01:22 AM
Did you guys find any P&H info? I have A schematic that might be useful
piperpilot55r@aol.com AKA; Flyingwrench
Old 02-28-2008, 01:59 PM
No I never have found anything on the P&H welder. Is the schematic for an engine driven or electric?
Old 07-23-2009, 05:45 PM
Lakin Gabbert Lakin Gabbert is offline
Hi, Bill, The welder I'm working on is a 7CCK-381E/4325J, Model WNP=225 CACV, sounds simular. I went thru the Onan it runs great, I need some info on the Constant Current / Constant Potential wiring and operation instructions. It works good as a A/C gen. It might also be useful as a ground power unit for 28 volt aircraft. I'll be satisfied for a port. D/C welder. If you turn up any thing please let me know. I'm checking with Aweco in Phoenix whose decals is all over this thing.. Lakin
Old 07-25-2009, 04:11 AM
Dempster Dempster is offline
This is from the FAQ section on the P&H Mining site.....
"Q. I have a P&H welding machine that needs maintenance or repair. What is my best course of action for this situation?
The P&H Welding business, along with all the technical engineering drawings and documents supporting the line, was sold in 1968. The firm that bought the P&H Welding business later on discontinued this product line.
Should your P&H Welding equipment require service support, we suggest contacting a local or regional welding equipment service support provider, one of whom might be willing to retro-fit old P&H Welding machines with modern components in order to restore them to working order. "
http://www.phmining.com/faq/index.html
So try local or other welder "repair" shops. Two examples I know of....
http://www.billswelderrepair.com/
http://www.stumpfsweldingsupplies.com/
General Electric Generad?? Welder info needed Don Smith Welding Shop 1 04-03-2008 12:32 PM
CP GW One Thirty Welder Info needed Don Smith Welding Shop 1 04-03-2008 12:31 PM
National Cylinder Gas, Co. welder help needed!!! MoRo Welding Shop 0 01-04-2007 06:27 PM
Hobart Simplified Arc Welder manual John Hamilton Welding Shop 0 10-10-2006 02:49 PM
GE Welder Manual? John Culp Welding Shop 0 12-22-2001 10:44 PM
