Horn Motor
Been trying to get the horn on my (6 volt) 1923 model Tt working. I'v cleaned the points and...
this thread has 6 replies and has been viewed 995 times
Old 10-07-2006, 09:46 PM
Will's Avatar
Will Will is offline
Default Horn Motor
Been trying to get the horn on my (6 volt) 1923 model Tt working. I'v cleaned the points and anything else thats looks like needs cleaning. All that it does make a sound like somethings hitting the tin plate but thats it, nothing else. Is there sposed to be a gap in the points and if so how do I adjust the gap? Whats the purpos of the adjustment screw on the top of the unit? Is there any sites that I can go to that can give me some mechanal insight to how it works? If I can get an idea of how maybe I can fix the why.
Thank you,
Will
Old 10-07-2006, 09:50 PM
Tanner Remillard's Avatar
Images: 10
Default Re: Way off topic but I'v run out of idea's
You might try the guys here, someone ought to know. http://www.mtfca.com/
Old 10-07-2006, 09:53 PM
Dustin D Ehli's Avatar
Dustin D Ehli Dustin D Ehli is offline
Images: 15
Tanner, there should be a flat head screw in the center of the back of the horn, you should try to turn it a little bit either way while trying to make it honk, i beleive this adjusts the "air gap" whatever that is, but i know if the screw is turned on a working horn it will stop working.
Hope this helps
Dustin
Old 10-07-2006, 09:54 PM
Images: 15
I mean't Will not Tanner
What was I thinking
Dustin
Old 10-07-2006, 10:40 PM
Will,
If it's a motor driven horn, the adjustment screw should be on the BACK of the motor case. It simply moves the motor armature (and serrated wheel) closer to the point on the tin diaphram, changing the tone (aooogha!). If it's a vibrator type I can't help .
Old 10-07-2006, 10:52 PM
Mark Bruto Mark Bruto is offline
the way horn works is as follows : the points are normally closed letting the electro magnet pull the diaphram in, as soon as it's in it is supposed to open the points allowing it to return to the normal position again closing the points. all this happens very fast making the diaphram vibrate to get the tone. it sounds like your diaphram is pulling in but not opening the points, check to be sure the diaphram is opening the pionts, it may need to be indexed in a certain position to make this happen. the adjust screw should allow for fine tuning the tone after it is working.
Old 10-08-2006, 10:08 AM
Are you shure you dont have a magneto horn? Try hooking up to your mag post and see if it works
Buck horn cutter Gramps 416 Antique Gas Engine Discussion 0 02-03-2008 09:23 PM
Oil field Green Horn John Davis Oil Field Engines 15 06-19-2007 11:08 AM
Van Horn Auction Randy Antique Engine Archives 7 07-11-2002 09:40 AM
Attendance? Van Horn Auction Roger, Northwest, CO Antique Engine Archives 1 06-25-2002 10:00 PM
Green horn needs help,,, Mike Wurth Antique Engine Archives 1 09-11-1999 09:48 AM
