[Home] - [HELP] - [Forums] - [Articles] - [Photo Gallery] - [Groups] - [Chat] - [Classified Ads] - [Subscribe] - [Links] - [Books] - [Sponsors]
Wisconsin Year? model TRA10D
Have a Wisconsin TRA10D single cylinder cast iron engine on a Bush Hog garden tractor & like to...
this thread has 7 replies and has been viewed 2745 times
Old 10-12-2006, 06:45 PM
olcowhand olcowhand is offline
Default Wisconsin Year? model TRA10D
Have a Wisconsin TRA10D single cylinder cast iron engine on a Bush Hog garden tractor & like to date the engine to approximate year of tractor. The engine serial # is 4308153. A year of manufacture would be GREATLY appreciated!
Expect it's a late 60's or 70 model. Cannot find any info to date the tractor itself, Bush Hog Corp. can't even help.-----------Daniel in ky
Old 10-12-2006, 06:56 PM
JKWidener's Avatar
JKWidener JKWidener is offline
Images: 26
Default Re: Wisconsin Year? model TRA10D
The following website says this "TRA-10D 3-1/8 x 2-5/8 10.1 HP @ 3600rpm made 1964-1976 Originally designed for tractor applications. "
From this website:
http://www.asecc.com/data/wisconsin-models.html
I hope this helps.
Old 10-12-2006, 07:01 PM
Thanks for reply JK, but I'm hoping for an exact YOM. I've seen that page, but doesn't home in on my tractor year. Hard to find info on these puppies.
Old 10-12-2006, 07:13 PM
JKWidener's Avatar
Images: 26
Here is a little more info i found on your engine.
Dont know if you have this yet but here is a website dedicated to bush hog garden tractors. With a registry.
http://www.bushhogtractors.info/
Old 10-12-2006, 08:08 PM
Yes, been there too, but seems nearly impossible to date these things. Best guesses are just that. My best chance is dating the engine. Year of tractor will likely be the same as YOM of engine, or the following year. I started my own Yahoo group for Bush Hog tractors as the other owner is AWOL & no moderator.
Here's the link if soomebody would like to look or join:
http://groups.yahoo.com/group/bushhog_gardentractors
Old 10-12-2006, 08:59 PM
WaterlooBoy2HP WaterlooBoy2HP is offline
Many Military Wisconsin engines have the date on the ID tag. The number 4308153 is on an engine that was dated 1967. That number is not far from your number. As Wisconsin serial numbers include all models made, your engine could be a 1966 or even a 67. At least this gives you a reference point if nothing else and puts you a bit closer.
John
Old 10-12-2006, 09:02 PM
John
My mistake. the number on the ID tag of the 1967 military engine is 4388315.
John
Old 10-12-2006, 10:20 PM
Thanks John, I have engine years by serial up to 58, & going by the same difference in numbers during these earlier years, if the spread stayed close to the same, then my engine would be about a 66. Thanks, that does narrow it a bit! BTW, have you done anymore to your IH dozer project?
Wisconsin Year? TRA10D olcowhand Antique Gas Engine Discussion 0 10-12-2006 06:40 PM
Year of Briggs model 500 Sky Small Air Cooled Gasoline Engines 3 07-22-2005 10:45 AM
What year and Model? will Antique Engine Archives 9 12-15-2001 10:17 PM
Maytag Model and Year Larry Kastens Antique Engine Archives 7 12-07-2000 11:54 PM
what year model? Wayne Antique Engine Archives 0 08-29-2000 08:25 PM
