may tag clutch
I was wondering. Is the kick pedal clutch gear cast iron or cast steel? the one on this mdl 92 is...
this thread has 1 replies and has been viewed 871 times
Old 10-20-2006, 03:31 PM
Ray Cardoza's Avatar
Default may tag clutch
I was wondering. Is the kick pedal clutch gear cast iron or cast steel? the one on this mdl 92 is worn and I'd like to know so i can build up the worn surfaces so i can get it running. thanks
Old 10-20-2006, 07:26 PM
Exclamation Re: may tag clutch
The gear should be cast iron , the bearings steel
How do you get the clutch off a FM 208? vern0n Antique Gas Engine Discussion 3 01-03-2008 11:59 AM
New Way CH Clutch J Neidig Antique Gas Engine Discussion 0 12-02-2007 08:06 PM
What does this clutch go to Eric McKenna Antique Gas Engine Discussion 5 06-26-2005 10:59 AM
Clutch Brad in Wisconsin Antique Engine Archives 12 04-01-2002 04:46 PM
Clutch? Hal Davis Antique Engine Archives 1 03-13-2002 03:05 PM
