eBay Auctions
Go Back   SmokStak > SmokStak® General Discussion > eBayŠ Auction Discussion
eBayŠ Auction Discussion All eBay™ discussion; engines, frauds, fancies, weird stuff and more.
Will go cheap on eBay What is it?
item=280040461525
this thread has 9 replies and has been viewed 1808 times
Old 10-21-2006, 11:16 AM
Jim Davis Jim Davis is offline
Default Will go cheap on eBay What is it?
item=280040461525
Old 10-21-2006, 11:49 AM
Default Re: Will go cheap on eBay What is it?
Looks like about a Wisconsin V-4, most were 15-20kw. This one might be a little bigger.
Old 10-21-2006, 12:46 PM
EricWood's Avatar
EricWood EricWood is offline
Agree with Wayne, looks light it may be the big V-4 Wisconsin made, the V-465. At 65 horsepower max, I'm not sure what RPM that is measured at, but most likely not 1800. If this one probably ran at 1800, I would agree with the 15~20 kW range--I think 25 would be pushing it too much for this motor at 1800.
Used to use the 465's in the service on military equipment, and they were always operated in the 3200~3600 rpm range.
Old 10-21-2006, 12:47 PM
Gene O. Carpenter's Avatar
Gene O. Carpenter Gene O. Carpenter is offline
Images: 15
My Kohler book say's that anything higher than 15 KW is liquid cooled! 10 KW was a VH4 (see my 10RMY62 VH4D powered 10KW in my profile) Virgil T has a 18RMY which looks about like this one....Wish it was nearer to me!
Gene
Old 10-21-2006, 07:26 PM
armandh armandh is offline
the homelite book that came with my 7200 watt kohler powered gen also showa a v-4 11.5KW gasoline model, on lp or ng probably 11KW
Old 10-21-2006, 10:23 PM
Jack Hottel Jack Hottel is offline
The 15RMY62 used a Wisconsin VG4D rated 32HP at 1800RPM. The pictures look exactly like the pictures in the manual, and thats what I believe it is. I also thought that this was the largest air cooled unit Kohler made. I put one up in NC in 2000 and it has proved a good, reliable unit.
Jack Hottel
Old 10-21-2006, 10:41 PM
Jack you nailed it and everybody else guessed right also. I just got the following new info from the seller:
"Here is some info that I got off of the unit. Gen: Model 15RM782 Serial: 157703 Motor: Teldyne Wisconsin, Model X4B7A, Serial 7309443, and another number that says Y-97. Hope this helps, please post this on your forum. Thanks."
I know he means 15RMY82.
Old 10-21-2006, 11:19 PM
EricWood's Avatar
Oops, Jim, I'll have to say I had it wrong on the engine model for sure!
Fuzzy memory; I guess I had forgot exactly what a 465 looked like until I dug out a picture--forget they were OHV engines.
Old 10-23-2006, 10:45 AM
Fatboy Fatboy is offline
Anyone read the feedback on this seller?
Fatboy
Old 10-23-2006, 02:15 PM
Yes,
Not too savory, at least in the beginning. It may be known dead/flooded, and not condition unknown/just missed the flood, you just never know.
I bought one that was supposedly condition unknown, untested, but after the fact, I wonder about it. It had a bad exciter stator. After these things change hands several times, the chain of knowledge does get broken somewhere along the line.
Cheap place for JD gaskets? vern0n Antique Tractor Talk 3 03-31-2008 07:29 PM
What would be a CHEAP hit&miss for a beginner and would anyone have one? Hit and Miss kid Antique Gas Engine Discussion 99 01-07-2008 12:16 AM
1/2 autolite sparkplugs cheap Chuck Woycke Antique Gas Engine Discussion 23 08-06-2007 05:28 PM
Large Engines cheap Pacrat Antique Gas Engine Discussion 8 09-15-2006 11:43 AM
1/2 sparkplugs (cheap) Chuck Woycke Antique Gas Engine Discussion 23 08-23-2005 04:54 PM
