International Harvester LA & LB Engines
this thread has 26 replies and has been viewed 30124 times
Old 10-23-2006, 08:46:01 PM
bwze bwze is offline
Default International Harvester LA & LB Engines
Hey folks, first time poster here. I'm really enjoying the site and kudos to all who help manage it. My dad just recently purchased two International Harvester Hit and Miss engines. One's a LA and the other is a LB. I've been researching and trying to find some historical info and pretty much anything dealing with these machines to aid him in his planned restoration. I've done a few searches of the forum and have succeeded in finding a few tidbits on the subject. I really, however, am looking for a little more detailed information. Can anyone point me in the right direction for a source of this type?
Old 10-23-2006, 08:53:35 PM
Doug Kimball's Avatar
Images: 76
Default Re: International Harvester LA & LB Engines
bwze,
Try this link for a manual.
http://www.oldengine.org/docs/IHC_LA_OM.pdf
Old 10-23-2006, 09:26:56 PM
Randy Werner Randy Werner is offline
Does anyone know if there is a link for the IHC 1 1/2 M early under stricker. Thanks. Randy
Old 10-23-2006, 10:23:07 PM
Tom G Tom G is offline
LA & LB engines are throttle governed, not hit & miss.
Old 10-23-2006, 10:23:19 PM
Colin Rush's Avatar
Colin Rush Colin Rush is offline
Default Binder Books
Call Binder Books at 503-684-2024 for any and all manuals for the International Harvester and McCormick engines. They have the manual for the LB, for the LA, for the early Ms, and the combination one that covers the later Ms and the L and LA.
Old 10-24-2006, 06:08:50 AM
What exactly is a throttle governed engine......with respect to how a hit and miss engine works?
Old 10-24-2006, 06:20:08 AM
Terry Beasley's Avatar
Terry Beasley Terry Beasley is offline
Throttle governed engines work exactly like your modern lawn mower engine with a governor opperating the butterfly in the carb to control speed. A hit and miss uses the governor to latch the exhaust valve open untill the engine slows enough for the governor to unlatch and let the exhaust valve operate again. The engine just coasts and does not take in fuel while the exhaust valve is latched open.
Old 10-24-2006, 08:33:11 PM
KeithT KeithT is offline
Before He tears them apart, tell him to loook good through the rear inspection plate at how the linkage going to the carb [right under the piston] is set. Thats usually the hardest part on them to re-time to get it back running.The governor assembly near the flywheel turns this linkage going to the carb to control speed and is preset with tension. My dad had A LA in the shed for years, said he was going to rebuild it, I finally did two years ago and got it running.Somehow I ended up with 2 LA'S and 3 L B'S, a Hercules, a Stover, a Massey Harriss, and I think I got a bug of some kind out of that old L A. and I cant name any more for I'm afraid my wife may read it.
Old 12-13-2007, 04:10:20 PM
Jim Poteet Jim Poteet is offline
howdy... i am jim poteet, austin tx. work on import cars... found an old, LB Intl.harvester stationary engine in a field. all there and not too rusty still free. one rocker is broken... missing valve springs and keepers. oiler also missing... this one will likely run if parts can be found. there is an `antique tractor and stationary engine meet in stonewall tx, mid june. looking for pieces thanks,..
Old 12-13-2007, 08:48:51 PM
Francis Francis is offline
Go to this site and you will find a manual for a LB - http://www.oldengine.org/members/allen/techindex.html
Old 12-13-2007, 11:58:25 PM
Donnie Devore Sr. Donnie Devore Sr. is offline
way to go keith
Old 12-14-2007, 05:16:19 PM
Images: 12
Hey Jim, that Stonewall show is now on Hwy. 16, at the Gillespie county fairgrounds, about 3 miles South of Fredricksburg, on the West side of the Hwy.
Old 12-14-2007, 07:35:19 PM
Johnny T Johnny T is offline
If you need parts or a manual for la's or lb's go to one of the sponsors on here www.hitnmiss.com then print off the manual. They have almost all the parts needed to get an la or lb engine running at a reasonable price.
Johnny
Old 07-02-2012, 12:11:59 AM
elhoppo elhoppo is offline
My LA has no linkage to carb and no butterfly throttle.It just sucks up the fuel from tank with a check valve tube and mixes with air.What do they call these enginesIt has an outside governor control arm to set the hp.When i tore it apart the gov controls the valve system,the engine coasts for a while before it hits.
Old 07-02-2012, 02:26:42 AM
pjjms pjjms is offline
Then it's may not be an LA. The LA will have a throttle butterfly in the inlet port in the head, not in the carb. The linkage to it is not visable with the engine assembled as it goes through the crankcase directly into the head.
If your engine has a governor working on the exhaust valve it may be an M or even a Mogul. Can you post a picture of it?
Old 08-01-2014, 09:30:01 PM
ballfour ballfour is offline
I have an IH LA that I can't get running smoothly. I have taken the side plate and the head off and cleaned the governor linkage. The engine will start but idles down and will die unless I choke the engine, then it will throttle up and die down again. Have tried to preload the throttle linkage spring before installing the head - the engine ran smooth but way to fast, had to pull spark plug wire. Any suggestions will be appreciated.
Old 08-02-2014, 05:03:47 AM
Dale Barnett's Avatar
Dale Barnett Dale Barnett is offline
Images: 16
First thing that comes to mind is the check valve on the fuel line. Make sure that little ball it is seating and not letting fuel drain back.[reason you need to choke it]
2nd is the fuel line where it screws in to the carb-mixer as they are known for sucking air at this point due to soft white metal cracking and stripping the threads out.
3rd you had the head off so make sure that the little throttle shaft [butter fly] connector is not binding on the head gasket as this is a very common problem.
4th the butter fly should be wide open when not running and the gov. will close it to regulate speed.
Dale B.
Old 08-02-2014, 05:07:38 AM
BMiller's Avatar
BMiller BMiller is offline
BWZE, where are you in South Carolina? There are quite a bunch of us old engine guys here. There is a new show on the 16th in Piedmont, SC (near Greenville) -- just show up, Identify yourself to one of the guys exhibiting, and get ready for the conversation you'll get.
Bill Miller
Old 08-09-2014, 11:02:29 PM
Have checked all of the items you listed. Replaced the check valve and verified that it is working properly and checked for leaks in the line. When I take off the back cover, the governor mechanism works smoothly and does not stick in any position. The butterfly is open when not running. Also have taken off the carburetor and checked the governor from the back cover and it works smoothly. Based on your comments I think I will recheck the fuel line connections for leaks.
Thanks for your help
Old 08-10-2014, 11:10:12 AM
Farmall Jod Farmall Jod is offline
sounds like a check valve issue to me...
had a Massey R-14 with the same problem, would barely run unless the engine carb was near completely covered or "choked".... after a lot of hair pulling realized the check valve was letting fuel drain back into tank and the vacuum to draw fuel wasnt capable of keeping fuel supplied unless I was "choking" the carb and creating more vacuum.
replaced the check valve and problem cured
---------- Post added at 09:10 AM ---------- Previous post was at 08:53 AM ----------
sorry didnt read the part about changing the check valve, but it does sound like a vacuum leak between the chek valve and carb to me
International Harvester LA Billy Boone Antique Gas Engine Discussion 5 07-28-2007 06:18:52 PM
International Harvester LB 1 1/2- 2 1/2 Chad Schlifke Antique Engine Archives 2 11-17-2003 05:51:12 PM
International Harvester Tony Page Antique Engine Archives 4 04-01-2000 02:10:15 PM
Re: International Harvester Tony Page Antique Engine Archives 0 03-31-2000 09:52:50 PM
Re: International Harvester Harry Antique Engine Archives 0 03-30-2000 10:56:03 PM
