b & s oil filterI have a Coleman 3500 wt 7hp ohv commercial briggs and stratton engine. I bought it used. I would...this thread has 2 replies and has been viewed 703 times
I have a Coleman 3500 wt 7hp ohv commercial briggs and stratton engine. I bought it used. I would guess it to be about 6 years old.
It has a screw on type oil filter. the model # is no longer readable and without it Sears can't identify the oil filter I need. Does anyone know the filter # used? thanks, mike coco |
Ignoring your mention of "coleman" and "briggs stratton" -
Focusing on your mention of "sears", "3500", "Oil filter" - You may have a Generac generator (made for Sears) with a GN series engine. These engines have oil pumps (briggs don't), and can usually be identified by "OHVI" embossed on the valve cover. If so, your oil filter is likely Fram PH4967 or equivalent. Steve |
Zeromedic,
thanks for the reply. I must have been high on exhaust fumes when I posted Coleman, the generator is a craftsman. Other than that, I bet you are right. The cover says OHV and I did not actually see B&S, I just assumed it was. I will check out the filter you mentioned. thanks so much. mike |
| 5.0 BGA oil filter | sbaker80 | Onan Generators | 1 | 09-05-2006 07:52 AM |
| hyd. filter | rvhop | Antique Tractor Talk | 0 | 08-16-2006 11:11 PM |
| TD-40 Fuel Filter | 20 Reeves Highwheeler | Antique Tractors - Old Iron Lugs, Cleats and Tracks | 1 | 06-22-2006 09:26 PM |
| Air filter | Mark K | Antique Gas Engine Discussion | 4 | 12-27-2005 09:27 PM |
| Onan MEP 016B Military Fuel Filter & Air Filter (Help) | Doogdoog | Onan Generators | 8 | 04-30-2005 10:43 PM |
