Welding Shop
6 Volt or !2 Volt Battery?
Hi, I just got a old Lincwedler/Generator and it didn't have the batteries.... Does anyone know...
this thread has 4 replies and has been viewed 1157 times
Old 11-05-2006, 01:47 PM
chrisjm chrisjm is offline
Default 6 Volt or !2 Volt Battery?
Hi, I just got a old Lincwedler/Generator and it didn't have the batteries.... Does anyone know what system it is set up for? Is it 2- 12 Volt batterys or a 2 6 Volt batteries?
Boy any help would be much apprreciated
chris
Old 11-06-2006, 10:07 AM
K D Redd K D Redd is offline
Default Re: 6 Volt or !2 Volt Battery?
Try contacting Lincoln with you model number and ask if they still have info on your welder. A few years back I was able to get a wiring diagram for my OLD DC 180 powered by a THD Wisconsin. The only electrics on this old welder is ths mag and the generator for the welding current.
Or you might, if you think it was originally 2 6 volt batteries try one 12 volt. One 12 volt is the same as 2 6 volts connected in series. If the one 12 volt does not work it must have used 2.
Kent
Old 11-06-2006, 12:04 PM
td5doug td5doug is offline
If its a 225 3as, it will use 2 12 volt batterries in series to create 24 volts. this is used to motor the generator & start the engine.
Old 11-19-2006, 08:29 PM
B. K. Lahey's Avatar
B. K. Lahey B. K. Lahey is offline
Images: 17
Hi BD, my son-in-law just swapped from acetylene to profane ,mainly to get away from the $130+ a year rental, also you can get your profane at any servo. Got to buy different tips (mixers) for the hand piece but it makes a beautiful cut, bit hard to light in the wind but ya, I'd go for it if you are cutting and heating only, you cannot weld with it.
BK
Old 11-19-2006, 08:35 PM
Images: 17
Somehow this got in the wrong thread
BK
Hi Guys! Onan CCK 3CR 120 volt or 240 volt envelopes2007 Onan Generators 26 12-27-2007 09:38 PM
6 volt or 12 SKocher Antique Gas Engine Discussion 14 09-07-2006 09:20 PM
12 volt or 6 volt for buzz coils Will Magnetos, Ignition Coils and Spark Plugs 23 03-31-2006 03:19 PM
32 volt yes, 32 volt auto start Kohler Frank DeWitt Kohler Generators 4 08-01-2005 09:54 AM
12 volt battery and model T coil Sky Antique Gas Engine Discussion 5 06-13-2005 01:28 AM
