South Bend Lathe
I'm trying to set up a South Bend 9" benchtop lathe (model B9W & catalog number 477-R). It has a...
this thread has 5 replies and has been viewed 2678 times
Old 11-05-2006, 08:36 PM
Frank Martin Frank Martin is offline
Default South Bend Lathe
I'm trying to set up a South Bend 9" benchtop lathe (model B9W & catalog number 477-R). It has a set of step pulleys for the v-belt that provides the final drive. What I don't understand is how to put the v-belt on. It appears that the only way is to take the headstock apart, slip the belt around the pulleys and put everything back together. Ditto, for the pulley on the motor stand. Should I be looking for a belt with a split in it that can be unhooked and reattached. Naturally, the instruction manual is long gone and the South Bend "How to Run a Lathe" book is silent on the matter. Any suggestionsare appreciated.
Frank
Old 11-05-2006, 09:20 PM
KeithW's Avatar
KeithW KeithW is offline
Default Re: South Bend Lathe
Pulling the head stock apart to install the belt is not unusual. My Sheldon uses a flat belt. If I used an endless belt that is what I would have to do. As it is I use a leather belt and stich it together. I don't know if anyone makes a take apart v belt.
keithw
Old 11-05-2006, 09:41 PM
John Herald John Herald is offline
They do make take apart V-belts. Grizzly Industrial has one called "Power Twist V-Belt" - You just add or remove sections to fit your needs. Comes in 3/8 - 1/2 - 5/8 in 4 foot hunks for $23.95 -- there number is 1-800-523-4777
Hope this helps -- I think other places have them too! John
Old 11-06-2006, 11:29 PM
PFT's Avatar
PFT PFT is offline
Images: 31
Here's a picture of the above mentioned power twist v-belt, also available from Grainger Ind. Supply. ( www.grainger.com ) I use one on a small surface grinder and it works fine, good luck with the lathe. PT
Old 11-08-2006, 12:01 PM
Peter Peter is offline
I use that type of belt on a 10 inch logan and it seems fine to me. I was told by a machinist that was bad becasue it adds vibration and detracts from the finish cut. I am not a machinst, just pretending and its well within my needs.
Old 12-18-2006, 11:53 PM
GarysToys GarysToys is offline
Fenner Drives in Manheim, PA makes a link type belt to the same specs as a V belt. You tell them the size of belt you need and they tell you how many links are required.
It works great for applications like yours where you don't want to pull the shaft from the pullies.
Phone is 717 665 2421 or www.fennerdrives.com
South Bend Machine Shop Course Engine actionhac Scale Model Engineering 3 08-16-2007 02:03 AM
South Bend Lathe?? RIRR Machine Shop and Tool Talk 1 08-01-2007 10:26 PM
cutting south bend belt and regluing? schiarelli Machine Shop and Tool Talk 5 06-09-2007 01:51 AM
anyone know what model this is? (south bend) schiarelli Machine Shop and Tool Talk 8 04-02-2007 04:15 AM
South Bend Lathe engine project Greg Antique Engine Archives 4 12-12-2002 10:00 PM
