Steam Engines
Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Stationary Steam & Traction Engines
Stationary Steam & Traction Engines Antique steam engines, traction engines, their boilers and the related things that make them run.
Another buried steam engine
These stories just intrige me.... http://www.oldglory.co.uk/archive/12may04/ft1.htm
this thread has 5 replies and has been viewed 2198 times
Old 11-12-2006, 07:34 PM
JKWidener's Avatar
JKWidener JKWidener is offline
Images: 26
Default Another buried steam engine
Old 11-12-2006, 09:24 PM
Jordan's Avatar
Jordan Jordan is offline
Default Re: Another buried steam engine
thanks for sharing this with us
Old 11-13-2006, 09:36 AM
Brad Kelley Brad Kelley is offline
Images: 47
There is a locomotive that was buried in a tunnel collapse in Richmond back in 1925. The railroad sealed the tunnel and the train remains there today. Recently a group has proposed a plan to recover the locomotive and they began doing feasibility studies on the land. They drilled some holes into the tunnel and started pumping out water so they could lower in cameras and try to see what's down there. Last I heard, the city halted the project because of permits and concerns that pumping out the water could cause another collapse. There are homes built over portions of the tunnel. Here's some info:
http://www.vahistorical.org/news/richmondtunnel.htm
http://www.timesdispatch.com/servlet...=1149188806137
Old 11-13-2006, 01:53 PM
Colin's Avatar
Colin Colin is offline
Images: 138
interesting story. hopefully they can get it dug out was wondering what would make the boiler explode though you would think just pipes and stuff would break off causing burns. But if the fireman got out to tell the tale it must be true, but then again how could he survive a boiler explosion if he was right there firing it
Old 11-13-2006, 03:59 PM
survivingworldsteam's Avatar
survivingworldsteam survivingworldsteam is offline
Originally Posted by Colin View Post
interesting story. hopefully they can get it dug out was wondering what would make the boiler explode though you would think just pipes and stuff would break off causing burns. but if the fireman got out to thell the tale it must be true, but then again how could he survive a boiler explosion if he was right there firing it
My understanding was that it wasn't a boiler explosion per say; the tunnel caving in broke a steam pipe. The engineer was pinned between the throttle and the boiler when the cab was crushed and could not get away from the scalding steam; eventually, a hole was dug straight down from the surface to recover his body.
There is a picture of the "Steam Dinosaur" on the webpage at:
http://www.ranger.demon.co.uk/aveling/aveling.htm
A color version of this picture is on my Surviving World Steam Vehicle CD-ROM; although it looks like the record needs to be moved to my Surviving World Steam Locomotive CD-ROM.
The other Aveling & Porter engine at Cwt-y-Bugail quarry has since been removed. It is hard to believe that much can be salvaged from it to restore the other; and I assume the remainder would be destroyed in the process. It just doesn't seem quite right.
-James Hefner
Hebrews 10:20a
Surviving World Steam Project
Old 11-13-2006, 05:03 PM
Anywhere the rest of us non-subscribers to Old Glory can read about the 2nd engine that was salvaged? I'd love to see the "rest of the story" myself!
I know on old gas tractors, etc. often times it takes "two to make one", as I've always heard it called. Shame parts from two couldn't be duplicated to make two, with something this rare and old.
Mike M
Buried Engines Casemaker Stationary Steam & Traction Engines 122 02-27-2013 03:48 PM
Buried Steam and stationary engines JKWidener Antique Engine Photos 5 02-07-2007 01:36 AM
Steam Traction Engine Buried JKWidener Stationary Steam & Traction Engines 1 11-12-2006 07:20 PM
We're BURIED! Chris Kirk Antique Engine Archives 19 02-18-2003 02:28 PM
