Go Back   SmokStak > SmokStak® Antique Engine Community > Vintage Diesel Engines
Removing Lister injector body
Here's the head of the Lister CS all ready to remove the injector. It won't come off. How hard to...
this thread has 5 replies and has been viewed 748 times
Old 11-16-2006, 07:23 PM
Stans Stans is offline
Default Removing Lister injector body
Here's the head of the Lister CS all ready to remove the injector. It won't come off. How hard to I whack it? (just kidding )
Stan
Name:	head(med size).jpg
Old 11-17-2006, 08:23 AM
GeneratorGus's Avatar
GeneratorGus GeneratorGus is offline
Default Re: Removing Lister injector body
They usually come out pretty easy. Doesn't look like any rust on yours, probably just some gunk or carbon holding it tight. Try twisting a little while prying onder the body, if that doesn't work a ten pound sledge should do the job.
Old 11-17-2006, 09:38 AM
Jim McCracken Jim McCracken is offline
I have a thermoil diesel and I read to loosen ,( don"t remove) the bolts or clamp that hold the injector in place.Then spin it over and close the compression release.The compression was supposed to blow it loose.This is assuming the engine isn't
stuck.If it isn't,you might try belting it up to something bigger and try the above approach.Good luck !
Old 11-17-2006, 04:13 PM
ListerDiesel's Avatar
Stan
Stan:
I don't remember what year your engine was, but assuming it isn't a water-cooled injector (early CS engines) then it is probably just water running inside the rocker cover and sticking the injector to the head with rust.
Don't knock it, take out the retaining studs and get a large parallel jaw adjustable on the main body and give it a working backwards and forwards until it comes free. A liberal dose of diesel or penetrating oil during this excercise would be good.
Make sure you get the copper washer out underneath the injector at the bottom of the hole.
If by chance you have an early water-cooled injector, them it could be a long battle as the injector body is in contact with the coolant and does get rusty and oversized to pull out.
I think from your email that yours was a later engine?
Peter
Old 11-17-2006, 06:04 PM
It is a 1949 engine.
Stan
Old 11-18-2006, 04:51 AM
Stan
Then you're safe, the water-cooled injectors went out in the engines around s/n 14000 or so.
Peter
Any body have Font Experience? JKWidener Paint Shop 13 12-30-2006 06:38 AM
Any body need help at Pagent of Steam Shawn Perkins Stationary Steam & Traction Engines 5 12-11-2006 03:10 PM
any body know about ditchwitch? Mac Leod Antique Engine Archives 9 02-21-2004 09:46 PM
Lister-Blackstone fuel injector pump JODY Vintage Diesel Engines 1 02-28-2002 02:30 AM
Kargard Body & Engine Co. A. Brown Antique Engine Archives 0 10-06-1999 07:54 PM
