Less than 10 (Rare Engines)
this thread has 414 replies and has been viewed 102967 times
Old 07-16-2011, 12:35:28 AM
Skip Landis Skip Landis is offline
Default Re: Less than 10 (Rare Engines)
this one should qualify. skip
The Following 4 Users Say Thank You to Skip Landis For This Post:
Old 06-22-2012, 09:26:02 AM
Jesse Baggett Jesse Baggett is offline
I also own a 3 hp air cooled Olds
---------- Post added at 09:26 AM ---------- Previous post was at 09:22 AM ----------
I own one also
Old 06-22-2012, 05:36:22 PM
Oldsiron Oldsiron is offline
Jesse, it's realy rare if it is a 2aa 3hp,
Or is it the pump jack type?
Can you post s pic ?
Regards Chris.
Old 10-06-2012, 08:20:02 PM
Marv in Minn's Avatar
Marv in Minn Marv in Minn is offline
Sendling-Munchner 3hp
Kansas City Hay Press 10 HP
marv
The Following 5 Users Say Thank You to Marv in Minn For This Post:
  #325
Old 10-10-2012, 12:28:15 AM
m52a2 m52a2 is offline
I have a NOVO Model No. EF-4 3/4 x 6, it is a 4 cylinder engine with pairs of cylinders and seperate heads if memory serves me. ever heard of one ? I believe the model is the bore & stroke.
Old 10-10-2012, 01:20:32 AM
Les Layton Les Layton is offline
Yup I have one & they start easy & run like a top. I'll check the numbers to be sure tomorrow. I call them a carnival engine because I remember them running out behind the carnival rides when I was a youngster. Les
The Following User Says Thank You to Les Layton For This Post:
  #327
Old 10-10-2012, 06:55:07 AM
JHFoster JHFoster is offline
marv
In the 2nd photo---It seems that the pulley/flywheel cast combo would be a nightmare to make.
Do not argue with an idiot. He will drag you down to his level and beat you with experience.
Old 10-10-2012, 01:25:24 PM
I checked my EF novo & it is serial no. 2916 Mine has two flywheels. One flywheel is inside a large cover along with a cluch, the other flywheel is in behind a large raidiator with NOVO embossed in the top tank. Problem is, the tank is iron & rusted out in several places. It is curently waiting its turn in the shop. Can't get a good picture of it right now. Les
Old 10-10-2012, 10:17:15 PM
DieselAddicted DieselAddicted is offline
Ok my rare one. 1924 Petter 12/14 S Oil Engine. Rare being in the horizontal configuration. Only one I know of in the states 4-5 known in GB I think It would sneek in under 10 total known.
The Following 6 Users Say Thank You to DieselAddicted For This Post:
  #330
Old 10-13-2012, 02:24:05 PM
Johnny56 Johnny56 is offline
Hello George,
Is this only for American engines???
I have 1 (8hp) La Fourmi.. only one known... 1 vertical La Fourmi (1 1/2 Hp) only one known. 1 Carette Bruxelles 3 Hp only 1 known. ....... 1 Brouhot Vierzn 3 Hp 1900 only 1 known and 7 others only one's.... A 12 Hp Japy only 4 known ...
And between only one and only four.... I dont known how menny.... And wath do You think about the engines of Kees Fitters and his friends??? You have to preview a lot of cups I think.
Greetings Johnny.
I hope to see You ones again at my place whit Your friends.
The Following 2 Users Say Thank You to Johnny56 For This Post:
  #331
Old 10-14-2012, 07:25:58 PM
George Best George Best is offline
Johnny,
Glad to see your post!
Of course it is not limited to only American engines.
You know I like that foreign stuff too.
I'm planning on being at Nuenen in 2013 with my "Engine Freak" t-shirt I got from you.
Not sure how much time I'll have next year for visits, but I always like to visit the Belgian collectors I know.
George
Old 10-14-2012, 08:25:11 PM
wagspe208 wagspe208 is offline
Does my new New Way 8hp horizontal twin count? I only found a couple registered on the New Way registry.
Wags
Old 10-15-2012, 10:59:08 AM
Marv
Marv,
Is that the engine Bill Ramsden had?
As for less than 10, it might be, but only due to the hp size.
A collector I know in Germany has what I believe is a 4hp one. He has a personal registery he keeps of these engines. His photo album of ones he knows of must have at least a dozen of them.
Old 10-15-2012, 11:33:43 AM
OTTO-Sawyer's Avatar
Photo Re: Less than 10 (Rare Engines)
While 5hp horizontal Monitor engines may not be all that rare, I have my Dad's old one that has the (supposedly) Super Rare Speed Change Pulley on it that allows you to adjust the RPM while it's running instead of having to shut it down to adjust the spring tension on the governor weight. It looks like a clutch pulley. You grab the big hand wheel and then turn the center knob to adjust the governor spring tension.
I need to either patch about a hundred pin holes in the gas tank, or make a new one for it one of these years. Of all the engines Dad had when I was a kid, I always liked this one the most, and after it changed hands a couple times I was finally able to get it bought back several years ago after being 'held for ransom' by the last owner, knowing how bad I wanted it back. But at least it's back where it belongs.
A few years ago I was also able to buy back Grandpa's old Sandwich Hay Press which Dad ran with the Monitor back in 1969 on Grandpa's farm for the "Show Before the Show" that he had to see if there was any local interest in starting up a Threshing show. The next year, in 1970, the Stephenson County Antique Engine Club was formed and the first 'Annual' show was held in Freeport Illinois. Some things are almost Destined to happen, and reuniting these two pieces of equipment seemed to be one of them, even though I had to jump through a lot of hoops to make it happen.
  #335
Old 10-15-2012, 09:49:27 PM
Trevor Alder Trevor Alder is offline
Don't know how rare but I've only seen one other. Our 16 Hp Lauson-Lawton Wisconsin portable.
The Following 3 Users Say Thank You to Trevor Alder For This Post:
  #336
Old 10-15-2012, 09:54:43 PM
Mike Monnier's Avatar
Hoarder
Not really considering that Springfield and Foos used a similar design for their small engines.
The Following User Says Thank You to Mike Monnier For This Post:
  #337
Old 10-15-2012, 10:57:30 PM
Henry Macomber Henry Macomber is offline
Banned
This is a 2hp Renee Engine, It is French, the name gives that away. I'm not real sure just how many there are, but I think it meets the threads criteria.
Old 10-15-2012, 10:58:40 PM
Keven Withers's Avatar
Keven Withers Keven Withers is offline
Images: 15
Originally Posted by George Best View Post
Marv,
George you started this thread with the 20 H.P. Stickney !!!! So please follow your own rules.
The Following User Says Thank You to Keven Withers For This Post:
  #339
Old 10-15-2012, 11:01:27 PM
Banned
Not sure why the picture won't load, I'll try it again, 2hp Renee, having a computer malfuntion I guess, I'll try again after I reboot
Old 10-17-2012, 02:12:14 PM
oeisales oeisales is offline
I have a Detroit Gasoline Engine, horizontal style. Looks like a Nelson Brothers design but tagged Detroit Gas Engine Works. Not saying I qualify but this engine isn't listed in the BYB or I haven't seen another one. Tried to upload pics but it's not letting me.
Bob Loos
Rare briggs engines Mike Harper Small Air Cooled Gasoline Engines 19 01-31-2007 12:00:07 PM
COOL RARE engines!!!!!!! Craig A Antique Engine Photos 3 03-17-2006 12:15:29 AM
Briggs rare engines Mike Harper Small Air Cooled Gasoline Engines 2 02-02-2006 04:52:22 AM
flywheel engines (and how rare they are) Sky Antique Gas Engine Discussion 25 12-16-2005 10:09:49 AM
why are "rare" engines rare? gary bennett Antique Engine Archives 14 07-24-2004 11:42:37 PM
