Steam Engines
Pickering Governor
this thread has 16 replies and has been viewed 2942 times
Old 11-21-2006, 12:38:53 PM
6point9diesel 6point9diesel is offline
Default Pickering Governor
Has anyone rebuilt their flyball governor to the point that they needed to replace the spring steel that the fly balls ride on? If so, could you please elaborate? Particularly, how did you determine which material to use?
I'm thinking I'm going to have to dig out my old college statics & dynamics books, but wanted to see if anyone has tackled this.
Thanks for any help/ideas, Paul
Old 11-21-2006, 01:42:30 PM
GaarScott GaarScott is offline
Default Re: Pickering Governor
Paul,
I haven't messed with a Pickering myself, but I believe that Ken Majeski is probably well suited to answer any and all questions concerning governors. I have had the privilege to speak with him some on this topic, but am far far from knowing too much on the topic. Best of luck.
Lawrence
Old 11-21-2006, 01:49:47 PM
KGC1615's Avatar
KGC1615 KGC1615 is offline
Get a hold of Suden1, aka. Joe G. He has previous posts here. He probably has some in stock as he rebuilds numerous governors.
Tom
Old 11-21-2006, 02:10:44 PM
PTraubert PTraubert is offline
eMail NOT Working
I rebuilt an early Gardner spring governor some 6 years ago. The biggest problem was drilling holes in the spring steel (purchased from McMaster-Carr).
Since spring steel can have high carbon content the drill needs to be harder than it. I found a solid carbit bit at a local surplus too store locally that did the trick. Unfortunatly carbide is brittle and chips easily so I got just enough use to make the new springs.
Patrick
Old 11-21-2006, 02:30:36 PM
Thanks for the help fellas. I surely appreciate it.
Patrick,
When you got your new spring material, did you simply measure the thickness of your old material? How has the governor worked since you've rebuilt it? Does it "wonder" at all?
Thanks again, Paul
Old 11-21-2006, 03:32:04 PM
Suden1 Suden1 is offline
Images: 8
Patrick,
Thanks again, Paul
Paul what do you want to know. The material is spring steel that has been blued and you do better if you punch the holes rather than drill them. What do mean about wonder as I never head this term before. If you want know more call me at 618 259 5458 in the evening
Old 11-21-2006, 04:57:11 PM
Leo Bard's Avatar
Leo Bard Leo Bard is offline
You can also try Paul Woodworth, registered on this site, at pwoodwth@adams.net He's the Gardner guy, but is usually happy to help.
Leo
Old 11-21-2006, 05:17:52 PM
Jim Mackessy Jim Mackessy is offline
I have replaced springs on my governor. I just measured the thickness and got blued spring stock in that thickness. Then I used a foot shear to cut the leaves to dimension, and a shim punch to punch the holes. I had bought some replacement leaves from a fellow who makes them, but the ones he had in stock were narrower than the originals, so I decided to have a go at making them myself. It's not a bad job if you have access to the equipment and the patience to work carefully to get the accuracy down. A commercial sheet metal shop probably could have made them in a tenth the time it took me, and more accurately to boot with some of the modern shearing equipment out there. McMaster Carr has the stock.-JM
Old 11-22-2006, 08:10:03 AM
I just wrote a note thanking you all, but my posting time limit ran out.
Sooo....
Thanks fellas for the reply. I appreciate it.
Suden1,
Wondering - the tendency for a governor to not hold a constant rpm. I believe some folks call it searching.
I'll post the reason I asked when I have a little more time. Thanks for your number. I'll definately keep it handy.
Thanks again,
Paul
Old 11-22-2006, 01:00:03 PM
Images: 8
The so called wondering is cause not the proper tenion on the balance spring as the pickering manual setting shows. And also by to much wear in the valve.
Old 11-22-2006, 02:23:17 PM
eMail NOT Working
Yup. I measured the existing steel with calipers and bought material as close as I could to the original.
Old 11-22-2006, 03:53:43 PM
steamgas steamgas is offline
where can i get a pickering governer manual?
tex holliday
Old 11-22-2006, 04:18:21 PM
Tom Cwach's Avatar
Tom Cwach Tom Cwach is offline
Thanks again,
Paul
You might mean wandering? I have used and heard the term "hunting" arround here to discribe a governor that doesn't hold a steady RPM
Old 11-22-2006, 06:01:35 PM
Hunting is the term I've heard and use as well.
Correcting hunt can drive you even when you THINK you know ALL about governors............
Some years ago, a guy not TOO far away sold a perfectly good 80hp Case as it wouldn't govern well.
Turned out to be mismatched pulleys so the governor was not running at it's rated speed..............
Old 12-02-2006, 03:17:57 AM
Thanks for the replies fellas. I've heard it called hunting as well.
Have a good weekend,
Paul
Old 12-02-2006, 01:18:50 PM
Ken Majeski's Avatar
Images: 42
Well... Once in a while governor problems can be traced to the engine being out of time hitting on one end more than the other... This can cause a jumping governor. Pickerings seem to pick up on this more than the other makes as they seem to be quicker... Getting things timed Right seems to make a world of difference.... If the governor jumps worse running one way than the other this is a good place to look...
Ken Majeski, Ellsworth Wis.
Old 12-02-2006, 03:01:28 PM
Gary K's Avatar
Gary K Gary K is offline
Images: 388
Ken is right on that, as an ADVANCE-RUMELY at Rollag is out of time . . . has been for many years, and the PICKERING governor is sensitive enough, it's picking this up, and it opens & closes slightly for every revolution of the engine.
The movements on a PICKERING or JUDSON governor aren't straight-lined, or right-angled, thus every movement of the weights has a different movement on the valve. That is, when the weights start moving outward, the valve moves the least, and the farther out the weights are, the larger the valve movements. That's why they can be overly sensitive when the weights travel outward to their limit, and will "hunt" under load. (The 110 h.p. CASE skid engine at Rollag is set that way, and needs to be tuned in!)
If a PICKERING or JUDSON governor isn't sensitive enough, release some of the spring tension to get the weights farther out. If too sensitive increase the spring tension to bring the weights farther in.
If the governor speed it too low, they become erratic, so check its speed.
Gary K
Pickering Governor RYJBA Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 08-05-2006 03:22:47 PM
Pickering Governor Rich Martz Steam Stationary Engines, Traction Engines, Steam Boats 4 12-08-2005 12:15:40 AM
pickering governor Scott ( boiler inspector) Steam Stationary Engines, Traction Engines, Steam Boats 3 10-19-2004 08:58:26 PM
Pickering Governor Jim Meres Antique Engine Archives 0 10-24-2001 10:35:24 AM
Pickering governor... Alex Antique Engine Archives 10 04-02-2001 11:44:28 PM
