1943 M-5 generatorDoes anyone know where i can get a 6-volt two charge voltage regulator for a Hercules positive...this thread has 3 replies and has been viewed 1064 times
Does anyone know where i can get a 6-volt two charge voltage regulator for a Hercules positive ground zxb 4-cylinder motor i have the part no. autolite TC-4323-c cant find one anywhere maybe someone out there knows a replacment part or where i can find one, Thanks Kurt
You have the correct part number for the M-5 however TM 9-1616 shows it to be a negative ground system (my unit is a neg ground also). The WW2 Army stock is SNL# F227-1-89500 which may help cross reference to another application.
Rich |
Kurt,
Is your regulator missing, or is it there, but the generator isn't charging? If it's the latter, it might be the generator instead of the regulator. Might need polarizing to get it going, brushes might be stuck or dirty, or...?? There's also a little fuse in the regulator that could be bad. <<Jim>> |
HELLO SIR
Ihave a M5 us army ganerator also its all up and running ok but does have some parts missing the problem i have is im not sure where to put the armature and field leads from the battery charging gen the manual says they come from underneath but there no obvious terminals for them .on the regulater there are four leads coming coming off one end and they dont seem to be shown in the manual wiring diagram this is a three phase 3kw gen . regards vic uk. ps you can e mail me on vic@victoreaton.co.uk any one that knows anything about these things seem few and far between these days . |
| 1943 army generator M5 | KBach1021 | Military MEP and Aircraft Gen-Sets | 2 | 11-28-2008 06:03 AM |
| 1943 Onan gen w/ Jeep | Kate R. | Onan Generators | 3 | 07-29-2004 02:33 PM |
| military generator pe95g 1943 | LARRY VAUGHN | Onan Generators | 4 | 10-09-2003 06:43 PM |
| 1943 Onan | Earl Schweizer | Onan Generators | 0 | 06-07-2003 07:46 AM |
| 1943 Onan | Lee Schweizer | Onan Generators | 0 | 09-10-2002 02:44 PM |
