rubber O rings
:confused: Where does one buy rubber 'O' rings for model engines,and what types are for long use,i...
this thread has 2 replies and has been viewed 625 times
Old 12-11-2006, 07:48 PM
Edwin's Avatar
Edwin Edwin is offline
Question rubber O rings
Where does one buy rubber 'O' rings for model engines,and what types are for long use,i hear Vicon 'O' rings are great if you can find them.anyone care to shed some light on the subject.
Ed
Old 12-11-2006, 09:00 PM
Frank Douglas's Avatar
Frank Douglas Frank Douglas is offline
Default Re: rubber O rings
Edwin, I have a small hit and miss model which uses a 1" dia. x 1/16 cross section O-ring. I just pick one up at my home supply store (I use Lowes or Home Depot) not sure what you might have up there in the far North. I think the ones I use are Viton and they seem to last for a long time. Maybe someone else might know more about O-ring materials than I do. I use camp stove fuel with a little 2-cycle oil mixed in. Seems to get plenty of lubrication on the top end that way. I run my little engine most all day long at the shows I go to during the summer and I have only changed the o-ring out two or three times in about 4 years. Good luck with yours.
Frank
Old 12-11-2006, 09:01 PM
jlbroadhead's Avatar
jlbroadhead jlbroadhead is offline
viton o-rings are more chemically resistant than buna-n, you should be able to pick them up at any auto parts store or order them from a warehouser such as Mc Master Carr. If your main concern is pumping water regular old buna-n should work fine.
rubber 'O' rings for model engines Edwin Scale Model Engineering 5 12-13-2006 11:10 PM
RUBBER TO STEEL WHEELS SONNY L Antique Engine Archives 8 08-25-2003 07:11 PM
Rubber Rod Bearing? Hal Davis Antique Engine Archives 4 07-12-2002 01:44 PM
Rubber checks Ed & Hit & Miss Enterprises Antique Engine Archives 13 06-26-2002 01:42 AM
rubber belting Roland Antique Engine Archives 1 07-16-2001 10:53 AM
